Topic: grey water tank leak Posted: 23 Oct 2020 at 2:33pm |
I don't think its polypropylene, The FWT is LDPE, low density polyethylene. Those are milky white in color typically. Opaque black colored tanks are generally ABS, I suppose it could be LDPE with carbon black in it.
If its polyethylene it can be difficult to adhere to but not impossible. ABS is easier. Hobie Kayaks are polyethylene and I repaired some cracks in mine successfully. I first stop drilled the cracks, then sanded the cracks and surrounding surfaces. Then, very important, I flame treated them, which activates the surfaces and greatly improves adhesion. You just wave a propane torch over the area. Then I used gflex epoxy from West Systems. Good stuff, much more flexible than standard epoxy. My cracks were in high stress areas and stayed closed.
jaydub
Posted: 23 Oct 2020 at 9:22am |
Well, they are quite flexible, so I am going to lay a guess of !/8 inch maximum. There are some opinions on the Forum that the tanks are ABS which would make for threading, I think. However, unless Forest River has changed the material, I don't think this is true. I am told it is polypropylene . I will report back when the RV repair shop gets to look at it. Cheers.
Jaydub
Posted: 22 Oct 2020 at 3:35pm |
Originally posted by mjlrpod
I am talking about actually drilling a hole and tapping (cutting threads into the tank, that would allow a plastic, or brass plug to be screwed in and permanently seal it) it, if it's a hole.
Tapping a hole is an interesting solution for a material which is very difficult to get an adhesive to stick to. You'd probably need at least a couple of threads engaging for it to hold. If you use NPT standard threads 1/2 inch thread pitch is 0.071 inches and 1 inch is 0.87 inch. So your probably want the tank wall thickness to be at least 0.15 inch thick for a half inch plug and 0.18 for a 1 inch plug. Anybody know how thick the tank walls are?
mjlrpod
Posted: 22 Oct 2020 at 11:57am |
I am talking about actually drilling a hole and tapping (cutting threads into the tank, that would allow a plastic, or brass plug to be screwed in and permanently seal it) it, if it's a hole. The threaded plug will last as long as the tank, as thats what it has in it now. But hey, it's your choice on how to fix it. Since you don't know what the leak source is, who knows if it would work.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
jaydub
Posted: 21 Oct 2020 at 8:28pm |
Sorry, but nature of leak is not known at this time. I do not believe the remedy you suggest would work. These tanks will not take adhesive, caulk, whatever, and a plug would surely not last. The repair shop made it clear that only a replacement would be a long-term solution to the leak but we are awaiting the tank being dropped and inspected. Cheers.
Jaydub
mjlrpod
Posted: 21 Oct 2020 at 3:23pm |
If it's just a hole in the tank, I would drill it out, and tap it with a pipe tap, and screw in a plug.
2017.5 Rp-172
2020 R-pod 195
I'll be rpodding
jaydub
Posted: 20 Oct 2020 at 8:41pm |
Yeah, everything is on hold. I maybe will never return to the U.S. as things stand. If they get Covid under control plus a vaccine, then there is hope. Yet, my lady may still be unwilling to go. Our health insurance rates were around $900 per person a month last year and I havn't even checked if they cover Covid. I feel sorry for the vast numbers of businesses down there that rely on us Snowbirds. But then, I feel even sorrier for Me! . Cheers.
Jaydub
Posted: 20 Oct 2020 at 7:27pm |
dang.. I thought it was open.. stupid plague.
Posted: 20 Oct 2020 at 1:31pm |
The land border is closed to nonessential travel due to Covid.
Posted: 20 Oct 2020 at 1:23pm |
If you are planning on snowbirding in AZ.. why not just go, and have it looked at there?
The parts from the USA issue is resolved, the RV mechanics are in high gear in snowbird areas, and most will come to you for a small fee, if any at all.
