  New Posts New Posts RSS Feed: Water hot in heater but barely lukewarm from taps
Topic ClosedWater hot in heater but barely lukewarm from taps
crankster78 View Drop Down
Direct Link To This Post Topic: Water hot in heater but barely lukewarm from taps
    Posted: 09 Oct 2020 at 8:36am
Greetings:
I don't use the water heater at all, I have it bypassed.  I heat water in a large pot on the stove.  It heats up just what i need in a short time and saves water.
Crankster78  R-179
Crankster 78 R-179 2015
Tim and Barbara View Drop Down
Direct Link To This Post Posted: 09 Oct 2020 at 8:45am
Thank you Furpod.   This is helpful.   Yes the third valve is closed.  The system worked fine in July - it was after we changed the faucet on outside shower that it stopped working.  So that must be the problem!  Your explanation of the DC circuit is helpful.   Didn't know that.  We think the faucet is flawed - it doesn't close properly.  So we're going to replace it again with a better one.
Thanks everyone!
Tim & Barbara, Ontario
JR View Drop Down
Direct Link To This Post Posted: 09 Oct 2020 at 8:55am
Before replacing the faucet you might want to just disconnect the faucet and plug the water lines then try your system and see if you get hot water in the sinks.  Just a thought.
Jay
179/2019
