R-Pod 179 Furnace fan noise - Event Date: 17 Sep 2020 |
Post Reply | Page 12> |
Author | ||
Overland Pod
Newbie Joined: 25 May 2020 Location: San Diego Online Status: Offline Posts: 3 |
Calendar Event: R-Pod 179 Furnace fan noise Posted: 17 Sep 2020 at 7:29pm |
Hello everyone,
I have a very noisy fan on the furnace of my Model 179. Doe anyone have experience with solving the fan noise issue. The furnace works well but the fan sounds as if it is hitting something when the unit heats up. It is quite annoying when one is trying to sleep. I'm open to all advice on getting access to the fan motor. I have tried to take it apart but have not been able to accomplish it. Please help if you have experience with this problem. Greg Heckaman
Overland Greg
Posted: 17 Sep 2020 at 7:42pm | |
It is possible that there is something in there that the fan is hitting. Can you get something like a fiber-optic inspection camera to take a look in there to see what is hitting? One of the "As seen on TV" items is a "Lizard Cam." It is relatively inexpensive and may do the trick.
Overland Pod
Posted: 18 Sep 2020 at 12:36pm | |
Thanks for the idea. It is hitting something. I need to figure out how to get it apart.
Overland Greg
Overland Pod
Posted: 18 Sep 2020 at 12:37pm | |
Thanks for the suggestion. I will look into it
Overland Greg
Ben Herman
Senior Member Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 355 |
Posted: 18 Sep 2020 at 10:38pm | |
Might be as simple as using a compressor set to high psi and blowing air in there to see if you can dislodge something. Wear goggles when you do so - might stir up a bunch of dust. Wouldn't take much to make annoying noises (small leaf, etc).
Posted: 19 Sep 2020 at 9:28am | |
The motor is double ended and runs two blowers, one for external intake/exhaust and one for internal air circulation. Might be useful to try to determine which side is making the noise.
If you can't get at whatever is making the noise its probably going to be simplest just to remove the furnace so you can put it on a workbench. Then disassemble it enough to get at the blower(s). Its not that hard to remove, take a look at this video to get the idea. |
podwerkz
Posted: 19 Sep 2020 at 10:08am | |
Save your battery, your propane AND your ears, get a catalytic heater.
Posted: 19 Sep 2020 at 10:15am | |
If you like breathing combustion products and risking CO poisoning......
geewizard
Senior Member Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
Posted: 19 Sep 2020 at 11:26am | |
Not so. I use a Wave3 catalytic heater. Not all catalytic heaters are the same. And we've been through this discussion MANY times before on this forum. |
If you're going to use an unvented propane heating appliance in an enclosed trailer, make sure you have a window open enough to let O2 inside in adequate amounts to sustain life, make sure your CO and smoke detectors are working well, and get really good medical insurance.
We heat with a West Marine electric heater when we have 120vac. Otherwise, when heating with LP we turn off the furnace at night and heat the trailer up in the morning while I'm making the coffee. A good down comforter makes sleeping quite comfortable. If it's well below freezing outside, enough to freeze the plumbing, it's not likely we'll be out camping. Regarding the catalytic heater from Camping world, please note one of the warnings in the product description: • For use in vented areas only From the Consumer Product Safety Commission's study of catalytic heaters:
