john in idaho
Topic: Item location on the tongue Posted: 30 Aug 2020 at 10:02am |
I have a 179 - 2015 model. I have two 6v GC batteries that are mounted up against the curve of the front of the body, making it very difficult to check water etc on the batteries and easily remove them for winter if wanted. They reside in a plastic box with lift off lid that came from the dealer when I bought the rig new, which is difficult to access and marginally secure. I want to put the batteries in a Harbor Freight box with a hinged lid, but would have to set the box forward about 6" to allow the lid to open without scrapping the body. I have been working on this project since March and we have not been camping so there is no urgency. I have plenty of battery cable. I came up with the idea of putting the propane cylinder back where the batteries are now since the propane cylinder has a recessed top valve, and attaching the new battery box where the cylinder sits now. I previously added a Jack-E-Up mount to the Trailer jack, and the box would b e a convenient place to store the jack when traveling. I have the limited welding capability and scrap steel. The propane pressure regulator could attach to the new box somewhere.
Any one have any comments about this modification?
Thanks
Mirado
Posted: 30 Aug 2020 at 12:56pm |
I have two 6V batteries, and probably the same Harbor Freight box. In my case, I was able to move the propane bottle forward just a few inches and mount the box almost against the front of the trailer body. The lid touches the curve of the front when open, but does not cause any damage or scraping. I also mounted the propane regulator on the side of the Harbor Freight box, with no hose modifications. I will admit the batteries are not real convenient to get in and out of the box...but I only need to do that twice a year. My thinking was to keep the batteries as far back from the ball as possible.
Miriam and Doug
2015 Rpod 181G
Silverado 1500
Pod People
Posted: 30 Aug 2020 at 4:56pm |
I also have a 2015 179. We have 2GC-2 on the front end, single propane and the spare tire. I have a welder friend who did the work. We moved the propane tank forward as far as possible-we have a manual jack, so it was smaller. That would help add some usable space. One thing to consider if you use a wdh is the location of the contact points on the A frame. I could not use a box-one came mounted on the trailer when I bought it, but I took it off. But regardless, my wdh interferred with the box. the only way was to add more height to the frame( as I recall about 2 1/2") but that would mean you have to move the box forward to clear the front body curve. then my spare wouldn't fit.
good luck Vann
Vann & Laura 2015 RPod 179
Pod People
Posted: 30 Aug 2020 at 4:59pm |
Sorry, I meant to include the picture Vann
geewizard
Posted: 30 Aug 2020 at 5:48pm |
I use one of these on my 177 to hold two Group 24 batteries:
No need to move anything other than the plastic battery boxes (to the trash).
You can do a search on here and see my pics of the installation
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
Posted: 31 Aug 2020 at 5:43am |
I also have a 179 with dual GC2's. I use two of these boxes.
I didn't need to modify the battery rack. The tops do press slightly against the front wall but come off and on no problem. Not difficult at all to check the water levels, etc.
As far as holding the batteries well, the straps are fine. Remember that trailers are not airplanes, they are not subjected to negative g loads. The only way those batteries are going to come out of there is if the rPod rolls over, maybe. If that happens then that will be the least of my worries.....
Posted: 31 Aug 2020 at 8:55am |
We used this box for our GC2's.. didn't have any issues servicing them. We stay plugged in, so don't remove for the off season.
john in idaho
Posted: 31 Aug 2020 at 9:19am |
All valid points. Thanks. Back to the garage. One can get too complicated by over thinking. I do like the removable Jack so I can open the tailgate of the pickup when hitched up.
geewizard
Posted: 01 Sep 2020 at 7:31am |
My installation on the 177.
voisj
Posted: 01 Sep 2020 at 10:54pm |
Here's My harbor freight Box. I couldn't get to the handle easily, I had to move the tank forward and then with the second tank it worked good because i could just grab the handle between the tanks
SLOPODMODS
John&Sue,SLO,CA
