Robin Davis
Topic: Cracked shower pan Posted: 06 Jul 2020 at 8:56am |
Is it hard to replace my shower pan or should I use flex seal?
One Happy Camper
Woodmiester
Posted: 06 Jul 2020 at 3:19pm |
Yes, replacing the shower pan is quite a task. You will need to remove the wall paneling (the pan extends up behind the panels). It can be done, but work carefully so you don t break your wall panels. The problem with using flex seal is that it doesn’t prevent further cracking. Also, be careful disconnecting the drain pipe. You certainly don’t want to break that.
Swampfox
crw8sr
Posted: 06 Jul 2020 at 6:59pm |
One of the first things I learned on this forum was to reinforce the shower floor.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Woodmiester
Posted: 06 Jul 2020 at 7:15pm |
Crw8sr, Been thinking about doing the same thing. Did you get under the pan from the front? Don’t shower in there often, but would like to prevent cracking when I do😂
Swampfox
crw8sr
Posted: 06 Jul 2020 at 7:25pm |
Took the vent grill off at the shower floor, inserted wood scraps with construction adhesive.
Chuck & Lyn
Izzy, Morkie. RIP
2018 R Pod 190
2019 Traverse
Robspod
Posted: 06 Jul 2020 at 7:36pm |
Thanks for all of your help with this was hoping for the easy fix 😊
One Happy Camper
Woodmiester
Posted: 06 Jul 2020 at 7:42pm |
Thank you Chuck. I will certainly do that. I think some dense foam strips may also work.
Swampfox
Robspod
Posted: 06 Jul 2020 at 7:44pm |
Why is the acrylic so thin?
One Happy Camper
crw8sr
Posted: 06 Jul 2020 at 7:55pm |
Probably to save a few bucks.
Chuck & Lyn
Izzy, Morkie. RIP
2018 R Pod 190
2019 Traverse
Robspod
Posted: 06 Jul 2020 at 8:15pm |
Can I pour a tile cement pan?
One Happy Camper
