Buffalohunter ![]() Groupie ![]() ![]() Joined: 12 Oct 2019 Location: Bellingham, Wa Online Status: Offline Posts: 57 |
![]() Posted: 05 Jul 2020 at 11:49am |
So I bought this used...2020...prod with a furrion radio installed. The previous owners, of which I have no idea who they were, set up the radio. I want to use it to the fullest but it requires a pin, that has been input but unknown to me. So anybody know how to reset the entire radio? Install a new pin? Or basically how to use this thing? I do not know the model but the search is on going. Thanks for any suggestions.
R-pod-2020 189
2013 Toyota Tacoma |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6437 |
I did a quick search and found this on the Furrion site: Stereo functions lock up on the Entertainment System or Bluetooth function is not responding to device.
• Press RESET with a sharp object such as a clip to reset the unit and load its factory default settings.
Now, where the RESET is located, I don't know as we have a Jensen unit. RESET is the answer to more than one problem in the Furrion FAQ. |
RoverPod ![]() Senior Member ![]() ![]() Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
The reset is on the bottom left right next to the headphone jack. |
This is such a great site...following all the above instructions... I can now listen to Steve
Winwood, Clapton JJ Cale and other favorites inside or out using the Bluetooth function. Much thanks. Every time I read this forum I get great ideas...caulk the under cabinet sink. Life is good...camping at the potholes area in the dry deserts of eastern Washington...kayaking and hiking.
R-pod-2020 189
