  New Posts New Posts RSS Feed: RPOD 190 DeWinterizing
Topic ClosedRPOD 190 DeWinterizing
PODNNJ View Drop Down
Direct Link To This Post Topic: RPOD 190 DeWinterizing
    Posted: 30 Apr 2020 at 2:13pm
Hello-
This will be my first time dewinterizing a 2019 190.... it was winterized by the dealer.
Do they by default closes the valves to the water heater? Also.. does anybody have a picture of the water heater valve setup on the 190's?
Thanks in advance
mjlrpod View Drop Down
Direct Link To This Post Posted: 30 Apr 2020 at 3:43pm
When winterized, the water heater should be bypassed. If you can find the access to the tank inside the camper, usually under a dinette, bed, or removable panel, there are usually 3 inline valves. the water into the tank should be turned in line with the hose going in, the out, inline with hose going out, and the center should be perpendicular to the hoses. You might need to find the fresh water pump and turn off the intake valve there also. There are you tube videos on everything else
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
PilotPodder View Drop Down
Direct Link To This Post Posted: 30 Apr 2020 at 7:32pm
The water heaters in most pods are the same. I have a dewinterization video for the 179 that may help. ~PP
Direct Link To This Post Posted: 01 May 2020 at 7:12am
Thanks.. helpful info and great video.
It seems like in the video you only turned two valves... I'm just curious how I'd know which ones to turn, does the valve have any indication on it which tells you which way the handle should be?
I was under the impression that when the valve was shut it was in a T form and when it was open it was in line with the tube(sorry if that's confusing) just don't want to turn the wrong valves etc.
Direct Link To This Post Posted: 01 May 2020 at 7:46am
You have that right, if the valve handle is aligned with the pipes its open, if at 90 degrees its closed.
KB7LAK View Drop Down
Direct Link To This Post Posted: 03 May 2020 at 4:41pm
Dude, thanks for your videos.  Seriously, I love my R Pod, but they tell you nothing at the dealership.  So I've probably ruined the water heater and the pump so far through ignorance.
I think if I can get the stuff straightened out, I'll be OK.  But I know what to do now.
Direct Link To This Post Posted: 03 May 2020 at 5:09pm
The pump may be okay. They can run dry. As long as it was not for hours on end, it probably survived.
Direct Link To This Post Posted: 03 May 2020 at 5:13pm
The pump works, but hopefully the tank isn't ruined.  At least the trailer didn't burn down.
2019 RPOD 172
2012 Yukon XL
Direct Link To This Post Posted: 03 May 2020 at 5:28pm
If you had the electric element on it might be cooked, the gas is likely fine. You can get a new electric element without replacing the whole water heater. Fill and try the gas first and see if that works.
Direct Link To This Post Posted: 03 May 2020 at 5:47pm
It was just the gas. I was boondocking on batteries.
Ok, water works, and I'll get this running.
What's the next thing they didn't tell me?
2019 RPOD 172
2012 Yukon XL
