  New Posts New Posts RSS Feed: Outside sprayer attachment
Outside sprayer attachment - Event Date: 26 Mar 2020
Ron W View Drop Down
Post Options Post Options   Quote Ron W Quote  Post ReplyReply Direct Link To This Post Calendar Event: Outside sprayer attachment
    Posted: 26 Mar 2020 at 7:07pm
Have a new 2020 r pod 190. Can’t figure out how to connect the outside sprayer?
Kup-Pod View Drop Down
Post Options Post Options   Quote Kup-Pod Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 7:09pm
If nothing has changed from recent years, I don't think there should not be anything to connect per se, perhaps the small push valve on the shower head is not open?
2017 RP-178
2018 Hyundai Santa Fe XL
"Lead me on a level path"
Post Options Post Options   Quote Ron W Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 7:19pm
The new 190 comes with a sprayer hose and the attachment is on the opposite side from the shower. The hose won’t connect?
Post Options Post Options   Quote Kup-Pod Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 7:22pm
ok, you got me... this is an option I don't have so it's beyond my wisdom! :-)
Sorry about that!Embarrassed
2017 RP-178
Post Options Post Options   Quote Ron W Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2020 at 7:53pm
Thanks for the attempt!
RoverPod View Drop Down
Post Options Post Options   Quote RoverPod Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 7:02am
It's a quick connect connection. You need to slide the collar back and push the connector from the blue hose into the port. You need to PUSH really hard.
Post Options Post Options   Quote Ron W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 8:55am
Thanks I’ll try that. Maybe I didn’t push hard enough.
Post Options Post Options   Quote Ron W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 9:14am
That worked. You were right. It got a little easier to connect after I did it a few times. Really had to push hard. Thank you😄
