6v vs 12v |
Post Reply | Page <12 |
Author | ||
Olddawgsrule
Topic: 6v vs 12v Posted: 08 Jan 2020 at 7:56am |
Review here: http://www.youtube.com/watch?v=EcVjPap9dkY I'm not sure which group, but other members speak well of it. I've yet to wire it (still very cold out there..).
s2anderson
Newbie Joined: 28 Apr 2020 Location: Newberg, OR Online Status: Offline Posts: 4 |
Post Options Quote Reply Posted: 01 May 2020 at 12:16pm | |
Olddawgsrule,
New (to us) RPOD and it turns out that our battery (I assume original) needs to be replaced. I've been looking at a 6v option but I'm concerned about the tongue weight given our TV is close to being maxed out. Curious what adding the dual 6v did to yours? Thinking about maybe locating them rear of the axle to mitigate (perhaps the storage compartment in back).
2017 RPOD 180 Hood River
2014 BMW X3 xDrive28i |
Post Options Quote Reply Posted: 01 May 2020 at 12:33pm | |
I had the 6V option. Two 6V batteries weigh about 120 lbs. I now have a single LiFePO4 battery that weighs about 30 lbs. By changing, I was able to relocate the battery to an inside compartment since the Li batteries don't produce combustible hydrogen gas. That is the reason you can't relocate the lead-acid batteries to an inside compartment. You would be creating an explosion hazard. Also, if something happened to where the charger started doing the bulk charge mode and the electrolyte was low or the battery/batteries had a bad cell, the excess current could heat the battery to the point of boiling. Then you get hydrochloric acid fumes which are very bad to breathe. I've experienced that when I was in a tracked vehicle wile I was in the Army. We could not stay in the vehicle. I don't recall if it was a bad voltage regulator or bad batteries, but it was really bad. If you could make an isolated compartment with ventilation, then it might be possible.Still, you are better off having them on the tongue. Behind the axle can cause stability issues if you take too much weight off the tongue.
Kenneth
Newbie Joined: 30 Nov 2021 Location: Virginia Online Status: Offline Posts: 1 |
Post Options Quote Reply Posted: 02 Dec 2021 at 8:56am | |
For those who are confused about choosing between 6 volt and 12 volt RV batteries for motorcycles and touring trailers, we offer these tips: Many 12-volt batteries on the market have an amperage of 50 Ah to 100 Ah. The average 6-volt battery on the market provides 225 amp hours, typically ranging from 160 Ah to 260 Ah. 6-volt battery systems have thicker and heavier plates that allow them to withstand the chemical changes inside the battery, so 6-volt batteries can be said to have a longer lifespan. But in terms of cost, 12-volt battery systems are inexpensive and available at most auto supply and battery stores.
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3224 |
Post Options Quote Reply Posted: 02 Dec 2021 at 9:17am | |
A couple months ago I had to retire a nearly 11 year old 12v Interstate deep cycle battery. Replaced it with a Trojan T-1275 12v golf cart battery. It gives 150 Ah and weighs 85 lbs. Am happy with the weight as I can now remove 3 truck rotors from the front stow area-giving my wife additional storage space. And now will be able to keep the 11% (in my case 320#) tongue weight for reduced sway on the 177.
Post Options Quote Reply Posted: 02 Dec 2021 at 1:26pm | |
That sounds like it weighs almost about as much as my diesel tractor battery. A real back strainer getting that 95lb thing up into it's tray.
Post Options Quote Reply Posted: 02 Dec 2021 at 3:49pm | |
Funny or not so funny thing is that the battery was almost $ 200 with tax and had no handles to pick it up but had 4 plastic tabs with slots strategically positioned. So . . . got some 1/2" clothesline rope and tied 2 ropes in a criss cross position. At least it can be picked up now, with some effort.
Mooree
Newbie Joined: 17 Jan 2022 Location: USA Online Status: Offline Posts: 25 |
Post Options Quote Reply Posted: 13 May 2022 at 7:13am | |
Deciding between a 6-volt and a 12-volt RV battery is easy if you know what you want. Since the cycle of a battery depends on its capacity, we can say a 6-volt battery has a longer life than a 12-volt battery. On the other hand, two 6-volt devices with a 225 Ah rating will continue to operate your RV unit for 5 to 6 days before the recommended charge (225 Ah รท 20 Ah per day = 11.25 days; 11, 25 days x 50% = 5,625 ).
