  New Posts New Posts RSS Feed: Lifepo4 battery
Lifepo4 battery
Olddawgsrule View Drop Down
Post Options Post Options   Quote Olddawgsrule Quote  Post ReplyReply Direct Link To This Post Topic: Lifepo4 battery
    Posted: 10 Nov 2019 at 9:20am
The deals out of China start tomorrow and 1 day only. I'm watching for a deal on a Lipo4 battery and here's the one topping the list.
This one takes a 14.6v charge (as we'd hope for) and normal operating voltage of 12.8 (also what we're looking for). Be careful of one that charge 12v and operate 12v, those typically are rated 12v to 9v discharge.. Being we'd only get about 30-40% usage from them.
This one is 80ah and charges at 10amps. I'd have to setup charging accordingly. Build in balance charging and wall-wort charger included. Price shown is shipped.
2017 182g SOLD / My Website
2017 Tacoma SR5
Truck Camper Build
2004 F150 Camper Build "My Overlander"
Post Options Post Options   Quote Olddawgsrule Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 9:25am
2017 Tacoma SR5
Truck Camper Build
DavMar View Drop Down
Post Options Post Options   Quote DavMar Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 6:25pm
My Lord Olddawgsrule for those prices I can buy three lead acid batteries for every one of those. Yes, I know they have more amp hours and discharge rate but my question is does it make economic sense over lead acid or even sealed glass mat batteries? I'm just wondering what is the advantage now of spending 3 times the money for lithium battery? Educate me please!
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
crazycoyote View Drop Down
Post Options Post Options   Quote crazycoyote Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 6:39pm
I quit buying directly from China, I don't trust dealing with them. In June I ordered 2 electric folding Trikes at $199.00 each, and waited 4 weeks for delivery, the package came, inside were 2 face clothes. Thank God I paid with a credit card, 4 more weeks, I got my money back from Visa. Not a good deal.
Tars Tarkas View Drop Down
Post Options Post Options   Quote Tars Tarkas Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 7:33pm
You have to be really careful about batteries from China from what I hear.  They use cheap, off-brand cells, cheap BMSs, and since Lithium batteries are Hazmat, there's no sending them back.
As for those e-trikes, you can't get one decent bike battery for $199!
Caveat emptor.
seafans View Drop Down
Post Options Post Options   Quote seafans Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2019 at 8:48pm
My concern that on the trailer tongue that bouncing will dislodge the plates in the battery and short out.  Personal experience with batteries.
1.Do not throw battery into water or make it wet
2.Keep the battery away from heat source
3.Do not throw the battery into fire or heat the battery
4.Forbid to hammer to trample the battery
5.Forbid disassembling the battery in anyway
Online Status: Online
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 6:56am
3x the price but also about 3x or more the cycle life so for boondock use where you cycle the batts a lot you break about even. But that’s not the real reason. The best reason is weight, or, more accurately, energy density. Lead acid gives you about 10 useable watt hours per pound, Li batteries provide about 5-7 times that. If you don’t need that much energy storage and/or weight in not an issue for you then for sure don’t spend the money on Li batteries.
2012 Toyota Highlander
Post Options Post Options   Quote Olddawgsrule Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 7:40am
Okay, let's address the concerns.
First, weight is the key item to me. I actually loose 100lbs of battery weight with minimal loss of amp-hours. The battery move move inside, reducing cable length to the charger and panel, also protecting it from excessive temperature. The Lithium can be brought into my home during the winter and used as emergency power bank (no off gassing). Cost for me is $160 more than what I bought my dual 6v's for.
As for buying from China, I've had good experiences buying through Aliexpress and Alibaba. I do recommend that you know what your buying and 'read' all the spec's carefully. I also check through all the forums I belong to and see if anyone has bought the product (or from) before. One of these batteries has been purchased before (The GTK)
As far as buying batteries with cheap parts.. Don't have to go to China for that to happen.. Some of the best Lithuim Ion batteries are made in China. So, yes, there is good and bad being sold there. Know your product and research them.
I mentioned this above, yet I don't intend to mount to the tongue. No reason to. The reason your Pba's are out there is because they're too dangerous to have inside.
Lastly, Yes weight is the largest concern for me. I know what my power usage is (I boondock a lot) and I know what my recovery is so I know I can comfortably move to a 80ah battery. Every battery has a limit to cycles before they break down. How you cycle effects the life of the battery. My old LA solar battery bank was purchased new. 2 year limited warranty, said they would last 5-7yrs (lucky if I get 10yrs) and they lasted 17yrs. Cycling is key to longevity. Same for the Lithium battery.
I passed this along for anyone researching or looking for a Lifepo4 and wishes to save $$, here's a way.
2017 Tacoma SR5
Truck Camper Build
TheBum View Drop Down
Post Options Post Options   Quote TheBum Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 10:48am
One thing you need to be aware of, if you aren't already: LiFePO4 batteries have a very flat voltage curve. While that's nice while there's still charge in the battery, you have little to no warning when it runs out of juice and, consequently, accurate predictions of remaining charge from a monitoring perspective are almost impossible.
Alan
2016 R-Pod 179 "RaptoRPod"
2019 Dodge Durango GT Plus AWD
Three cats
Post Options Post Options   Quote Olddawgsrule Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2019 at 2:54pm
Okay, I'll bite... It's still a wattage thing..??!!??
2017 Tacoma SR5
Truck Camper Build
