  New Posts New Posts RSS Feed: Water pump
Topic ClosedWater pump
Johncmarshjr View Drop Down
Direct Link To This Post Topic: Water pump
    Posted: 14 Aug 2019 at 9:24am
the water pump in my 179 cycles on and off in rapid succession (1.5 second intervals) while using water.  Is this normal?
ALICE
Direct Link To This Post Posted: 14 Aug 2019 at 9:35am
Yes. You can install an accumulator if it bothers you, that will take care of about 90% of it.
Ephi82 View Drop Down
Direct Link To This Post Posted: 24 Aug 2019 at 8:05am
What if the pump cycles every 5 seconds when not using the water?
Grillin and Chillin
Glamping and Amping
Driving and Smiling
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 24 Aug 2019 at 8:15am
You probably have a leak somewhere.  At that rate it ought to be pretty obvious.
TT
FJ Cruiser
CharlieM View Drop Down
Direct Link To This Post Posted: 24 Aug 2019 at 9:28am
If the pump cycles that often and no leaks are obvious the pump internal check valve is faulty. Sometimes cycling the pump several times by opening and closing a faucet will clear it. If not, the check valve is easily replaced. Three screws and a repair kit from Shurflo.
