  New Posts New Posts RSS Feed: Axle falls off rv – nearly finished repairing
Topic ClosedAxle falls off rv – nearly finished repairing
Happy Tripping View Drop Down
Direct Link To This Post Topic: Axle falls off rv – nearly finished repairing
    Posted: 24 Jul 2019 at 1:13pm
As far as I can tell, I’ve now sorted out  the damage done when my R-Pods's axle fell off in our driveway, however one thing remains –a screw holding up the wiring bundle going to the right wheel has pulled out and the bundle is now loose. It screwed into the’ material’ lining the bottom of the trailer between the frame and the side. I say ‘material’ because I don’t know what it is, it is like cardboard that has been ground up and made into a sheet. Unfortunately, I cannot find a stud behind this to screw into for support, I don’t think there are any.
So, my question is - What is the best ‘fix’ for this? Seeing how flimsy the ‘material’ is, I’m not excited about just screwing into it, like Forest River did, but maybe (probably?) I’m wrong and the stuff is really quite durable.
Any suggestions are very much appreciated.
Our pod View Drop Down
Direct Link To This Post Posted: 24 Jul 2019 at 2:18pm
Affix the wiring harness screw too a thin metal plate and epoxy that to the weird underlayment.
Life is good.
mcarter View Drop Down
Direct Link To This Post Posted: 24 Jul 2019 at 5:30pm
Happy,
I have spent considerable time on the bottom. One thing I noticed is frequent use of sheet metal screws into a composite. You can't over tighten, it just doesn't make sense. I use a regular wood screw and some kind of sealant. Like Liquid Nails or a good adhesive caulk, sheet metal screws don't do well in composites. Move your new attachment point away from the original point. Good luck.
Direct Link To This Post Posted: 25 Jul 2019 at 9:04am
Depending on where the harness came loose you could also use SS self tapping screws into the frame or cable tie the harness to the axle or something else solid under there.
GlueGuy View Drop Down
Direct Link To This Post Posted: 25 Jul 2019 at 3:10pm
I just finished installing our E-go, and I can say for a fact that self-tapping screws into any part of the frame was an exercise in frustration. Any self-tapping screws had to be pre-drilled. We ended up using cutting oil and progressive pilot holes for all the through-bolts.
There were numerous spots where I was able to use heavy-duty UV-stabilized tie wraps though.
Motor7 View Drop Down
Direct Link To This Post Posted: 25 Jul 2019 at 4:30pm
That's odd, when I installed my under hanging spare tire carrier I used some large self tappers and they went right into the frame with no pre-drill and no issues. I must have used half a dozen per side.
2016 R-Pod 176T
Direct Link To This Post Posted: 25 Jul 2019 at 6:11pm
Interesting. When we did the hide-a-spare we drilled through holes for some 5/16 SS bolts. That also required cutting oil and progressive pilot holes. We only needed 4 of them though.
podwerkz View Drop Down
Direct Link To This Post Posted: 25 Jul 2019 at 8:44pm
Not all self-tapping are self-drilling, and although they may seem like one is the same as the next, I find that TEK is a good brand of self-drilling screws.
Direct Link To This Post Posted: 26 Jul 2019 at 4:22am
+1 The Tek brand is to self drilling fasteners as Kleenex is to facial tissue. Good stuff, especially if you have lots to install. If you only have one or two pre drilling and using self tappers is fine too. Self tapping screws have a pointed tip, self drillers will have a fluted tip.
