  New Posts New Posts RSS Feed: Generator for 189
Topic ClosedGenerator for 189
Babysaph View Drop Down
Direct Link To This Post Topic: Generator for 189
    Posted: 02 Jul 2019 at 2:12pm
Will a Honda 3000 run all of the stuff on my 189
Dr. J.R. Chambers II
TheBum View Drop Down
Direct Link To This Post Posted: 02 Jul 2019 at 5:00pm
It probably won't run the AC compressor and the microwave at the same time, but either of those devices individually and everything else, yes.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Motor7 View Drop Down
Direct Link To This Post Posted: 14 Jul 2019 at 11:12am
I think you will need a 3500 watt genny to run a 13,500 btu ac?
2016 R-Pod 176T
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 14 Jul 2019 at 11:30am
My Yamaha 2400ishc runs my air con.  I can't turn on the microwave without turning off the air, but that's never been problem.
There are compromises no matter what generator you choose.  My priority was quiet running (with enough power for the air).  A bigger generator might be better but weight goes up faster than watts so you really have to think about how you're going to load and haul a 3000+ watt genny.
And be aware that at most campgrounds there are quiet hours that prohibit generators, and sometimes they aren't allowed at all.  I always check beforehand.
Direct Link To This Post Posted: 14 Jul 2019 at 11:34am
I run my a/c on a Honda 2k (nothing else can be turned on at the same time). The Honda won't start the standard a/c, but if you install one of these it will start just fine.
Direct Link To This Post Posted: 14 Jul 2019 at 5:11pm
I run my AC on a 2K Generac. I do disable the converter charging loop. If I have to recharge the battery I don't try and run the AC.
Direct Link To This Post Posted: 14 Jul 2019 at 6:56pm
mcarter, does that 2kw genny actually start a 13.5K BTU ac without an easy start? Very interesting if its able to.
Direct Link To This Post Posted: 15 Jul 2019 at 3:46pm
Yes Sir it does. I have no east start. I spent the better part of a day testing this. What I learned and reported was I had to disable the charge circuit.
mjlrpod View Drop Down
Direct Link To This Post Posted: 16 Jul 2019 at 7:18am
Disable the charge circuit = ??   I think my box will be different than yours, as it is different than my 172 was. But how do you "disable" the charge circuit?  I have a circuit breaker labeled " converter " , not sure if that might do it.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Online Status: Online
Direct Link To This Post Posted: 16 Jul 2019 at 9:32am
That would do it. Turn off the main breaker for the converter, and the converter (AKA charger) should be off.
