tongatam
Topic: Awning not extending Posted: 18 May 2019 at 11:31am |
I just got my 2019 179 home, and the awning doesn't extend. It's the new power one, and not sure how to manually override that. Any help is greatly appreciated as the manual are... lacking at best.
2019 179 R-Pod ~ Daisy Mae
yesterdays are over my shoulder, so I can't look back for too long.
there's just too much to see, waiting in front of me.
Posted: 18 May 2019 at 12:29pm |
As with anything electrical, first confirm that power is available by checking that the other loads/appliances are working. Then, check the fuses (for dc equipment) or the breakers (for ac equipment).
Welcome!
podwerkz
Posted: 18 May 2019 at 2:35pm |
Fuses, switches, power...then call the dealer. That should have been checked or demonstrated to you at the dealer.
teampitt
Posted: 18 May 2019 at 4:02pm |
Check out this thread. See if the fuse is the problem with yours.
http://www.rpod-owners.com/forum_posts.asp?TID=12423&KW=power+awning&PID=118312&title=brand-new-thule-crown-power-awning-dead#118312
tongatam
Posted: 19 May 2019 at 8:31am |
Originally posted by teampitt
Check out this thread. See if the fuse is the problem with yours. http://www.rpod-owners.com/forum_posts.asp?TID=12423&KW=power+awning&PID=118312&title=brand-new-thule-crown-power-awning-dead#118312
Exactly what is happening to me! Thank you! They did walk me thru the process and it worked at the dealership. It's not working now, which points fingers to that fuse. Will check it out!
tongatam
Posted: 19 May 2019 at 3:20pm |
Yep, that was it! All fixed!
tongatam
Posted: 03 Jun 2019 at 10:22am |
well it WAS all fixed.. till we drove to the next adventure and BAM... blown fuse again! Called the service dept and they suggested using a higher amp fuse (20 to be exact) as it's a 'common' issue with the new power awnings. FYI! Will try it out and see if I can actually use my awning...
GlueGuy
Posted: 03 Jun 2019 at 1:18pm |
Does that indicate that the awning is binding or something? That would cause it to pull more amps. OTOH, maybe they undersized either the fuse, or the wiring or both.
tongatam
Posted: 04 Jun 2019 at 8:28am |
the service guy at the RV center said he's run into this quite a bit (not sure why they don't swap out the 15 amps then!) and said they undersized with the new set up. The fuse doesn't have a place in the main box either and is in a red container kind of flopping around behind the panel. Like an afterthought... we are swapping out the 15 to 20 this weekend and will let ya all know how it goes!
