  New Posts New Posts RSS Feed: My version of axle support plan B
Topic ClosedMy version of axle support plan B
 Post Reply Post Reply Page  <1 234
bhesse View Drop Down
Direct Link To This Post Topic: My version of axle support plan B
    Posted: 09 Aug 2019 at 1:58pm
Can you share your plans/drawing/parts list?
this looks like an easy mod that the earlier axle support, just need a welder  :-)
2015 RP-178
Direct Link To This Post Posted: 09 Aug 2019 at 2:24pm
My solution? It does not require any welding. Just a 2x2x3/16 or 1/4 inch inch steel angle crowned in the center and clamped to the bottom of the axle tube at each end using 2 ubolts (4 total) each at a 45 degree angle to the vertical on opposite sides on the diamond axle tube. The ubolts are square, 1/2 inch dia with 3.5 inch jaw spacing. Here are the parts and where I bought them:
Www.uboltsdirect.com
Order ID: 306166791
(5T12-3.5-SQ) S08 - 1/2" x 3 1/2" Inside Width      $4.50 X 4 = $32.00
(5T1216) (Length: 6")                               +$1.00
(DN12SUW12) (Add Nuts & Washers: 1/2" Deep Nuts & U-Bolt Washers)
                                                    +$2.50
(B2162FF) U Bolt Tie Plate - 5/8" Hole X 3 1/2" Inside Width
                                                  $10.50 X 4 = $42.00
Be sure to measure your axle tube between the torque arms and subtract 1/4 inch so you have 1/8 inch clearance on each end when you bolt the angle up. The crown is 1/4-3/8 inch and has to be pressed into the el not the flats. If you have a trailer or frame shop nearby with a press they should be able to do it no problem. When you bolt the angle up keep the ubolts loose until you get all 4 nuts started.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 12 Aug 2019 at 11:07am
Order ID: 306166791
                                                    +$2.50
                                                  $10.50 X 4 = $42.00
Interesting thread and do like what you've done to get outboard support to the axle. In another thread (and I think mentioned above) is your axle re-enforcement. I ask, vs. having the angle bent, could you place a 1-2" section (piece) of the 1/4" steel in the middle, then clamp the ends? My mind says that would increase the support, but also says I've added stress already and possibly weaken it.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 12 Aug 2019 at 12:22pm
My alternative is a bit more complicated since I fabricated brackets. However, the process of bending the angle using a tow chain and hydraulic jack would work if you simply wanted to bend it and then use the U-Bolts to clamp it in place. See my mods for how I did it.
Direct Link To This Post Posted: 12 Aug 2019 at 1:10pm
I read further along and see someone did ask the same question. Understand the points made for bending the steel.
Looks like my second thought was better.. Glad to see you folks went through that and worked through it.
Thank you for posting the link.
Now to read more of it.
Byways no Highways
2017 Tacoma
Truck Camper Build
