  New Posts New Posts RSS Feed: furnace
Topic Closedfurnace
mdballou View Drop Down
Direct Link To This Post Topic: furnace
    Posted: 02 Apr 2019 at 11:59am
Hi all, buying an R Pod. Was wondering about the furnace. 20,000 btu. Figure that is gas, but think in also has a fan that needs to work. Is it a 12 volt or 110 volt fan? Thank you for any help.
GlueGuy View Drop Down
Direct Link To This Post Posted: 02 Apr 2019 at 12:52pm
The burner is gas. The fan is 12V.
crw8sr View Drop Down
Direct Link To This Post Posted: 02 Apr 2019 at 5:25pm
Since the furnace is noisy we use a Vornado for heat.  It does a good job of keeping us warm.
Works as a fan too.  And since the A/C is really noisy we use the fan a lot when it's not terribly hot.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
lostagain View Drop Down
Direct Link To This Post Posted: 02 Apr 2019 at 6:13pm
If we have shore power, we use a West Marine electric space heater.  If we don't have ac, we use a Kelty 2 person 20ยบ sleeping bag.  It keeps us nice and warm and in the morning I turn the noisy propane heater on and in minutes it's warm enough to get up and start the coffee.  Soon, we're opening the vent in the head and turning on the fan to cool off.  And that's when it's below freezing outside.  That little space heats up fast.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 02 Apr 2019 at 6:59pm
The fan is 12v, which can mean power management if you're boondocking for a few nights in cold weather.  Since Pods aren't meant for really cold camping (the plumbing is too exposed), if boondocking some people use a Mr. Buddy heater instead of the furnace.  The furnace is really loud.
TT
FJ Cruiser
Dirt Sifter View Drop Down
Direct Link To This Post Posted: 02 Apr 2019 at 8:00pm
When on shore power, I use a small revolving space heater when needed. When not, the noisy propane works well and quickly for most mornings.
Direct Link To This Post Posted: 02 Apr 2019 at 8:55pm
and some people have built a heater with a small radiator plumbed through the water heater. Search around the forum, there are at least a couple of members who have built a heater from that. Using a small 12V fan makes it fairly quiet.
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 07 Apr 2019 at 5:41am
 If the furnace is truly noisy, remove it and check the impeller clearance on the exterior side intake. Mine was rubbing the inside of a plastic shroud. When I loosen the setscrew holding the blade and moved it a fraction of an inch. It made all the difference, noise level was much lower.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Live2Camp View Drop Down
Direct Link To This Post Posted: 08 Apr 2019 at 10:36am
Great tip, thanks!
2017 R-Pod 179 HRE (the green one)
His:Ford F150 double cab 4WD; Hers/mine:Tacoma V6 double cab 4WD
Still love rugged, diggin' comfy too
