mountain mist
Topic: Bed Making in 171 Posted: 27 Jun 2011 at 7:44pm |
I looked into Bed, Bath and Beyond and found a "sleeping bag". It was near $30, but might not be the same thing you are saw. Back from Texas, reached 104 some days. Sure glad to be home, but concerned for the children. Since I do not plan to go camping until the July 4th craze is over, I have a list that keeps getting longer to can get done before I feel I can leave Still do not know where I am going. I think Elkmont in the Park, but would like to have hookups. I can not afford a generator in order to have a fan going (not even asking for ac). Gets really sticky early in the night. Since nothing was done to my garden while I was gone (and lucky us, we did have a lot of rain)I am busy weeding and taming the plants that are taking over. Have a sick friend and need to make some freezer meals for her before I even think of going. My daughter says I am going to have to do better than making first trip of the year in July. She has that right! Hope everyone is getting out and camping.
'11 Forest River r.pod 171
'10 Ford Edge
ESCAPE POD
Trudi and Austin mini-schnauzers
change here, Trudi has gone, Austin now has a small black schnauzer buddy, Bentley
Hodge-PODge
Posted: 27 Jun 2011 at 4:43pm |
That's a great price! Thanks for the info.
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
blissful
Posted: 27 Jun 2011 at 2:53pm |
Since this last posting, I forgot to mention that Bed Bath &Beyond sells a bed-bag for around $20. Give it a try! Blissful
Hodge-PODge
Posted: 07 Jun 2011 at 3:58pm |
2011 Mercedes ML350
mountain mist
Posted: 07 Jun 2011 at 3:52pm |
Hod-PODge. Being my age, I have pitched a lot of things, 'specially anything that is going to keep me from doing something I WANT I like clean sheets, clean hair and feet in my bed. And the sack you are speaking of was expensive, not needed for much of anything else (I guess it could have been used while tent camping, but I had plenty of great sleeping bags). Unless I am camping in the Fall with iffy weather, I don't like flannel at all. Rather be cold than hot. AND if the hubby was along , the sheets would be his responsibility, since he would not tolorate untucked ones(Marine Corps training).
'10 Ford Edge
ESCAPE POD
Hodge-PODge
Posted: 07 Jun 2011 at 1:17pm |
Outbound,
I like the simplicity of your setup, and thanks for the reminder that we ARE camping. I was just lucky to find my Travasak, and maybe I did complicate things with such a detailed explanation.
That's me - always making things more complicated than they really need to be!
2011 Mercedes ML350
Outbound
Posted: 07 Jun 2011 at 11:57am |
This year, I put a 2 1/2" memory foam topper on our 171's bed (I had to cut down the length a couple of inches so that it would fit correctly). I put the fitted sheet just on the topper. The flat sheet, I just casually flick/drape on top, followed by an unzipped sleeping bag (a good quality one in matching colour to the R-POD's interior) used as a comforter.
Its neat enough. We're camping afterall, not staying at the Hilton. No need for hospital corners.
-edit-
I should probably mention that I attached a heated mattress pad to the memory foam topper (small safety pins on the underside of the topper) which is very nice on cool nights.
mountain mist
Posted: 07 Jun 2011 at 11:43am |
OK, yall let me know if you come visiting. As I said, a coverlet covers many unmade beds. Too much work, I have sheets clean smelling, 2 flats spread out and covered with a pretty coverlet. SinceI am telling, Everyone knows, but otherwise, no one knows that everything is not fitted. I move around a bit, but this is much better than sleeping on the ground, I don't complain if I have some gathering around me in the bed. Dog loves to get it "just right" anyway and that means a bit of messing it up! Guess what? I feel like I am camping, not having to make up the bed like at home. Even here I have a coverlet that covers all that fitted stuff.
'10 Ford Edge
ESCAPE POD
Hodge-PODge
Posted: 07 Jun 2011 at 10:13am |
I have a Travasak which is like 2 queen size sleeping bags (one on top, one on bottom) zipped together with sheets velcroed inside (but I think someone else has already explained that). I got it at a closeout store. I think Travasak has gone out of business - no wonder -- their prices were outrageous, but I got mine at a bargain.
But first, I did put a 3" memory foam pad (green tea scented from Overstock.com -- has no obnoxious odor like other pads) on the mattress, then a fitted bottom sheet with garters to hold in place to cover the foam and the mattress. The Travasak lays on top just like a sleeping bag. Just like techntrek posted above, I also have the bed made in 10 seconds flat. No more struggling.
If I didn't have the Travasak, I would use a fitted sheet on the mattress to keep the foam pad covered and the mattress clean, and then on top of all that I would have used 2 sleeping bags zipped together so I wouldn't have to make the bed. (You can also use sheets inside if you prefer. The top and bottom sheets inside the travasak are flat sheets and they are sewn together at the FOOT. Fold the sheets at the sewn seam so one is on top and one is on the bottom, then slip inside the sleeping bag by pushing the seam down to the foot of the bag - the sides of the sheet are open or velcroed to the bag). The convenience and ease of making the bed this way is unbelievable. And it's easy to pull the sheets out to wash them. It wouldn't be hard to make your own Travasak at all.
However, if you want to spend the bucks and the convenience is worth it to you (or if you just want to SEE how it works), follow this link to the RV Superbag which has replaced Travasak:
2011 Mercedes ML350
blissful
Posted: 07 Jun 2011 at 9:56am |
Mountain Mist WoW! You have that bed-making described to the 9nth degree!! I am a senior and the struggle made it almost impossible. I attached those sheet garters to the corners of the fitted sh*t before putting it on and it helped alot.
sweet dreams of sweat, Blissful
