Battery Box Attachment? |
Pushing70
Newbie Joined: 11 Apr 2018 Location: North Carolina Online Status: Offline Posts: 5 |
Topic: Battery Box Attachment? Posted: 23 Mar 2019 at 9:02am |
HI -- I recently found that the dealer-installed battery box on my 2018 Rpod 180 was essentially floating. That is, it was resting on the brackets with the plastic strap that holds the lid on routed around the brackets... The strap was the only thing keeping the box from bouncing out and onto the road!
Of course, I immediately added four SS bolts to hold the box to the bracket, but just wondering what is the customary practice for dealers attaching the battery box? Thanks and I look forward to your responses! Ely
73
Ely |
Posted: 23 Mar 2019 at 10:03am |
That's the way my battery boxes are. It's not a problem, a battery is not going to experience negative g forces to speak of. If the trailer bounces upward it and the battery will come down together due to gravity, the battery box and trailer aren't going to be pushing the battery downward. How could they, gravitational force is the same on everything? Any significant forces are going to be upward, forward, backward, or side to side which the brackets combined with the strap can handle.
Posted: 23 Mar 2019 at 10:24am |
Our original battery box had a couple bolts holding it onto the bracket along with a nylon strap. When replaced the battery with two 6V's I bolted the box down with bolts and large washers and drilled a drain hole in the bottom of the boxes to avoid water accumulating. There are also nylon straps holding the boxes and for theft deterrence I put a 1/4 inch chain with padlocks.
Lear111
Groupie Joined: 20 Oct 2016 Location: Montgomery, tx Online Status: Offline Posts: 66 |
Posted: 23 Mar 2019 at 11:42am |
Battery boxes were bolted down by one bolt each. I replaced the battery straps with ratchet type straps to facilitate removal. Similar to tie down straps much easier.
Posted: 23 Mar 2019 at 7:41pm |
I made a custom battery lock-down device which also serves as a battery hold-down device (see my mods, look for version 2). It works very well for both purposes.
Awchief
Groupie Joined: 04 May 2018 Location: Biloxi, MS Online Status: Offline Posts: 83 |
Posted: 23 Mar 2019 at 7:48pm |
That is the normal method of battery box install. When I went to twin 6 volts and new larger box I used self taping screws and also run the around the straps around the box base pieces.
Michael
Posted: 24 Mar 2019 at 6:10am |
For fun, (I know, I have a strange sense of what's fun ) I looked up the safety requirements in NEC Article 551 for securing RV batteries.
All it says is batteries must be secured to avoid displacement from vibration and road shock. So, putting the battery in its box and strapping the box is fine. The battery weighs 50-60 lbs and the box weighs about a pound. So, attaching the plastic box with screws or bolts isn't going to hold the battery in place, the strap does that. Meantime, propane cylinders are supposed to stay secure for 8x their full weight. Makes sense to restrain a bomb better than a chunk of lead I guess.
Motor7
Senior Member Joined: 09 Jan 2019 Location: E. TN Online Status: Offline Posts: 196 |
Posted: 24 Mar 2019 at 6:45am |
I added an inline 6v battery box and batteries. The box is taller and the bracket so close to the pod wall that I have to tilt the box forward to get the batteries in or out, so the only way to secure mine is with a short stout ratchet strap.
2016 R-Pod 176T
TheBum
Posted: 25 Mar 2019 at 11:36am |
Ours came with just a nylon strap. We changed over to these for a firmer and more theft-proof attachment:
http://b-drvbatterylock.com/ I'm now using dual 6V GC2 batteries with boxes I bought from Batteries + Bulbs. |
Alan
Posted: 25 Mar 2019 at 3:23pm |
I like my homebrew version 2 design better. The ones that go fore and aft on the batteries are harder to deal with Those are like my version 1 design.
