GlueGuy
Calendar Event: Brake Controller Question Posted: 01 Mar 2019 at 8:38pm |
+1 to Rich & Cindy. We have a factory (OEM) controller in our truck, and it is proportional by design, and it fits into a slot specifically meant for it. It also ties in with our console to indicate that it working & even how much pressure it's applying to the trailer brakes. I installed it myself, because it just plugs into the plug behind the dash. Easy peasy. Our truck did require it to be "activated" through the truck's computer system, but that was easy too with a tool (for Ford vehicles) called Forscan.
I do have to ask how much your Coleman pop-up weighs? In most states, you don't need a trailer brake controller if your trailer is less than 3000 lbs (that number does vary state-by state,, but it's a good rule of thumb). Also a half-ton pickup "should" handle trailers up to around 5,000 lbs without a WDH. Notn saying you shouldn't use one (we do), but it's not a make or break kind of deal.
Richand Cindy
Posted: 01 Mar 2019 at 8:05pm |
Since your truck comes with a tow package (i.e. 7 pin wiring pin), even though it did not come with the brake controller it probably has the wiring harness for one under the dashboard. Tekonsha makes adapters for all makes cars and trucks. We had the Tekonsha P3 installed in our Jeep Cherokee. Then when we bought our RAM truck we just purchased the adapter from Tekonsha (around $20) and took the unit out of our Jeep and installed it in the Ram. Took all of 10 minutes. It is plug and play. No need to find wires and splice into anything. Just look under the dash to see if you have an adapter or ask the service dept to show it to you. Your vehicle may already have a dedicated space on the dahboard for a brake controller. In that case it will look better and be able to use better if you have the dealer install a factory unit that is built in. It will cost a little more than any aftermarket controller but will look great as it is built in. All aftermarket controllers have to be screwed under the dash making it harder to reach and not look as clean. So do a YOUTube search for your truck and you may find your can simply plug in a brake controller in a few minutes and not have to pay someone to install it. So my recommendation would be have a dealer install a factory made controller that is built into the dash. If too expensive or there is no dedcated space for the controller have the dealer show you where the connector for it is. Then buy a Tekonsha P3 with an adapter plug made for the GMC envoy and install it yourself.
crw8sr
Posted: 01 Mar 2019 at 4:12pm |
Welcome to the forum and R-podding.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
IrishDream
Posted: 01 Mar 2019 at 3:50pm |
Thanks Alan (aka TheBum) !
Did some research based upon your comment and Offgrid’s last comment.
Learned that the CURT 51140 Triflex Brake Controller is currently listed as the top Trailer Brake Controller according to bestreviews.guide with a score of 9.9.
The previous quote of $175 installed that I’d been given earlier today was for the CURT 51120 model, which is the CURT Discovery that TheBum warned me about above. It’s bestreviews.guide score is an 8.1 and it’s listed as the 7th best trailer brake controller. Difference appears to be a mere $40 more for the 51140 model, which I’m planning on getting.
The CURT 51140 is a proportional brake controller. Also, the shop specialist assured me that the factory installed receiver on my GMC Envoy SLT is rated for a weight distribution hitch like the BLu Ox Sway Pro.
Listen to me! I almost (at least to myself) sound like I know what I’m talking about! Earlier this morning I didn’t even know there was a difference between a weight carrying hitch and a weight distributing hitch. And I had no idea what a brake controller was and whether I needed one. Now it turns out that I probably should have had both of them these past 5 years when trailering my Coleman pop-up!
Best to all. Have a nice weekend.
Jack
2019 1/2 Rpod 179 10th Anniversary Edition 2005 GMC Envoy SLT
TheBum
Posted: 01 Mar 2019 at 2:39pm |
I took a look at the Curt brake controllers. Avoid the Discovery and Venturer models because they appear to be time-based. If the description says "No leveling required" or "Mount at any angle", then it likely means it's not proportional.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Posted: 01 Mar 2019 at 12:51pm |
Yep, the extra kitchen space was a big selling point for us. We can pull things out and leave them on the counter without cluttering the dining table and still have room for a dish drainer. I'm sure you'll enjoy yours.
We never have more than the 2 of us and our Pomeranian sleeping in the trailer so no need to use the dinette area for anything but eating and sitting. No need for a larger bathroom for us, its not a room we spend any more time in that we need to .
The only issue for us as far as space is concerned is that the under trailer storage area is small. We use the back of the tow vehicle for that. Security on that stuff is one reason I prefer an SUV to a pickup as a tow vehicle.
Don't know anything about the Curt brake controllers, maybe someone else on the forum does. The $175 installed is a great price.
IrishDream
Posted: 01 Mar 2019 at 12:36pm |
Offgrid-
No I have not, but I will now sir!
IrishDream
Posted: 01 Mar 2019 at 12:30pm |
Thanks much Offgrid! Great advice in terms of having it done ahead of time. 7 way trailer connector factory installed on the GMC.
Have made a couple calls and looks like I can have a Curt Manufacturing controller installed here at a local qualified shop for $175, so that’s my plan.
Being recently retired, I told my wife that this old man can’t wait to learn lots of new tricks! As it relates to our upcoming Rpod Purchase, I cant wait!
Assume you like your 179? The rear kitchenette sold us. With most all the grandkids grown now, we decided we didn’t need anything more than a queen bed. Although we did opt for the Rdome also.
Thanks again!
Posted: 01 Mar 2019 at 12:24pm |
Oh BTW, while you're (wisely) checking that you have everything up to speed on your tow vehicle for your new rPod, have you confirmed that your receiver is rated for the heavier trailer and also for use with a weight distribution hitch?
Posted: 01 Mar 2019 at 12:12pm |
Either shop can probably do it, or any other shop that does RV work for that matter. Might want to get a couple of quotes. You'll want a proportional brake controller like a Tekonsha P2 or P3 or something similar. Or you can do it yourself, takes a couple of hours and you do have to crawl under the truck to run the wiring.
Do you already have a 7 way trailer connector on the GMC? If not you'll need that installed too.
If you have the rProd dealer do it and that's some distance away it might delay you getting back on the road quickly, so getting that done in advance might be wise.
