  New Posts New Posts RSS Feed: Panel under the fridge  in a r pod 179
Topic ClosedPanel under the fridge in a r pod 179 - Event Date: 07 Feb 2019
Lazy Goose View Drop Down
Direct Link To This Post Calendar Event: Panel under the fridge in a r pod 179
    Posted: 07 Feb 2019 at 1:40pm
Hi all was wondering what to do about the panel that wiggle under the fridge. It rocks back and forth, the wire showe awful design. Any ideas?
Direct Link To This Post Posted: 07 Feb 2019 at 2:50pm
Yep, it’s a weak spot for sure. So far I’ve just moved my panel over slightly and replaced what looked like drywall screws with self tapping sheet metal screws. When I run out of room for that I plan to use bolts and nylocks. Others have tried reworking the wiring, I’ll leave that to them for comment.
Direct Link To This Post Posted: 07 Feb 2019 at 3:56pm
Thank you. I just think that if the wires were put up because it causes the panel to push out.
JR View Drop Down
Direct Link To This Post Posted: 07 Feb 2019 at 4:06pm
I have a 2019 179 that I picked up the end of July last year (which still makes me a newbie) and trying to find out what is where I have had the panel under the frig off a couple of times and mine is mounted into some square steel stock behind the panel and it is secured with 4 beefy self tapping screws.  Which as I remember they are fairly long screws thus when reinstalling the panel you have to be careful to catch the square stock.  I haven't had any problem with mine panel falling off or pushing out either.  Hope this helps.
Jay
Jay
179/2019
Direct Link To This Post Posted: 07 Feb 2019 at 9:12pm
FWIW, we have had the panel off a couple of times, and it seems pretty secure. Further, the wire loom has an S curve in it, and it does not get hung up when the slide out goes in or out.
Is this maybe just an issue with east coast RP-179s?
john in idaho View Drop Down
Direct Link To This Post Posted: 08 Feb 2019 at 10:45am
2015 179 here.  My panel was held on by 8 staples, of which only two were into something solid.  A roll of paper towels got behind it underway, and it popped off when we ran the slide out.
Direct Link To This Post Posted: 08 Feb 2019 at 11:28am
It is a very bad design. Was thinking about replacing it with a better piece of wood on a hinge then place elastic across to hold shoes.
TheBum View Drop Down
Direct Link To This Post Posted: 08 Feb 2019 at 11:30am
Adding a hinge is on our to-do list, but the hinge needs to be able to swing both ways.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 08 Feb 2019 at 11:48am
True Alen, also thinking about using a long spring to hold up the big wire.
R&J View Drop Down
Direct Link To This Post Posted: 14 Feb 2019 at 1:26am
Yes we have done the same in the OzPod.
Rhona & John
POD: 2015 179 'OzPod'
Tow: 2014 Holden Colorado
