crw8sr
Topic: Need a screen door part Posted: 20 Dec 2018 at 9:42pm |
Sheet of aluminum from Menard's. Cut it to fit, a couple of screws, low cost, no paint, won't rust, light weight.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
podrunner
Posted: 20 Dec 2018 at 4:20pm |
Look on Amazon. Replaced mine a couple of years ago.
2010 R Pod 151
2017 4runner
2006 Honda Metropolitan
Pod People
Posted: 20 Dec 2018 at 3:56pm |
I don't throw much away!! I used the side of an old desktop computer case. It was strong , free and available. I cut it to the exact size, drilled the 2 holes, painted it black and it will last forever
Maybe I should start a business selling them!! would $50 be too much?? Just kidding
Vann
Vann & Laura 2015 RPod 179
GlibGuy
Posted: 20 Dec 2018 at 2:42pm |
Great idea! And one of my RV buddies owns a machine shop. Thanks
MICK
Happy Tripping
Posted: 20 Dec 2018 at 10:15am |
Originally posted by Pod People
I had the same problem... I made a metal plate that is the same size and thickness with holes in the same place. paint it black and screw it on. It will last forever.
Vann
I had the same problem. As far as I can see, there is NO metal plate available. Even if the advertised latch says its metal, the plate is still plastic.
Vann -- ?What metal did you use? I'm thinking thin brass might be best.
Pod People
Posted: 20 Dec 2018 at 8:36am |
I had the same problem. Mine broke near the top , below the top screw hole. I think it comes from the plastic handle being pushed out when the door is closed. I made a metal plate that is the same size and thickness with holes in the same place. paint it black and screw it on. It will last forever.
Vann
GlibGuy
Posted: 20 Dec 2018 at 7:58am |
The plastic plate in front of the screen door handle on my 2015 178 has broken*. I'm wondering if I can find just that part? There is a local dealer and I may check with them but is there an on-line site with maybe some parts diagrams or micro fiche?
Would appreciate anything, Mick
*I think the main door closes too tight and has caused it to crack
MICK
