  New Posts New Posts RSS Feed: finding wall framing
Topic Closedfinding wall framing
JerryCk View Drop Down
Direct Link To This Post Topic: finding wall framing
    Posted: 04 Dec 2018 at 9:26am
I really appreciate all of the advice from you guys. I think the thermal "footprint" on the outside, transferred to the inside by measurement (the wall is adjacent to the door) will work for me if the stud finder doesn't. We don't have much humidity but with temps in the 20's, the warmer surfaces ought to show.
The thin square tube behind the wall skin seems like a good application for jack nuts or toggle bolts, say 10-24,  for a strong connection. The toggles would probably have to be shortened.
The Wallbot sure looks like a "gotta have" to me - maybe Christmas?
voisj View Drop Down
Direct Link To This Post Posted: 03 Dec 2018 at 7:05pm
And I also have A wall bot, that thing is amazing showed the studs right edge to edge like a picture!
SLOPODMODS
John&Sue,SLO,CA
mcarter View Drop Down
Direct Link To This Post Posted: 03 Dec 2018 at 4:01pm
Thought so, kind of where I was headed 6 posts ago.
Direct Link To This Post Posted: 03 Dec 2018 at 3:59pm
To locate studs on the inside I used a really good stud finder one that also detects metal and electricity,be aware that the aluminum studs are only a sixteenth of an inch thick and you cannot use a power tool to install it or you will strip the out the aluminum.I ended up drilling a larger hole in the stud and using a plastic anchor.
SLOPODMODS
John&Sue,SLO,CA
TheBum View Drop Down
Direct Link To This Post Posted: 03 Dec 2018 at 3:51pm
I've wondered if this device would work:
https://walabot.com/diy#
Too bad it only works on Android phones.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 03 Dec 2018 at 3:39pm
How did you transpose that to the inside?
Kevinscamps View Drop Down
Direct Link To This Post Posted: 03 Dec 2018 at 12:17pm
I had no luck with a stud finder. The thermal camera worked great!!!
http://www.rpod-owners.com/forum_posts.asp?TID=12295&PN=1&title=thermal-pictures
Direct Link To This Post Posted: 03 Dec 2018 at 10:33am
JerryCk,
Here's an easy way to locate wall studs. A good Quality studfinder should work but you could do this,
Warm up the pod to 60 degrees at night, then turn it off,in the morning you should see this.
SLOPODMODS
John&Sue,SLO,CA
GlueGuy View Drop Down
Direct Link To This Post Posted: 03 Dec 2018 at 9:27am
There is a complete peripheral aluminum "frame" member (it's relatively small square aluminum  tubing). You can see how the frame is built in this Forrest River video. It's a bit dated, as they've replaced the luan plywood with Azdel.
Direct Link To This Post Posted: 02 Dec 2018 at 5:04pm
Thanks Mike.  I've got a stud finder. I'll give it a try. I wonder if there is a continuous strip where the side walls meet the ceiling and floor?
John Lundborg
