"The Shelf" |
Post Reply | Page 12> |
Author | |||
1tulip
Groupie Joined: 21 Feb 2015 Location: United States Online Status: Offline Posts: 44 |
Topic: "The Shelf" Posted: 16 Nov 2018 at 4:49pm |
So, I would like to add a shelf above the bed. I'm not sure how you can adequately brace a shelf in then flimsy wallboard. What do you pound in to the wall to hold things up?
Posted: 16 Nov 2018 at 4:54pm | ||
Look through my mods to see my solution (link in signature). At first, the shelf mostly rested on the valences. I changed out for anchors. If you use them, they need to be an inch or less in length. Any longer and you risk putting a hole in the side of your R-Pod (ask me how I know ). Between anchors and the valences, your shelf should be very stable if you don't overload it with heavy items. My CPAP machine and some clothing go on ours.
TheBum
Posted: 16 Nov 2018 at 6:34pm | ||
We put in end boards attached to the walls with industrial strength Velcro. We screwed brackets to the boards to provide ledges for the shelf.
Alan
Pod People
Posted: 17 Nov 2018 at 9:00am | ||
It may depeend on which model you have.Our 179 shelf goes front to back rather than side to side. I lowered the tv to make the necessary room. I sude a wire shelf from Lowe's and cut it to length. I put an angled cleat on the ceiling using construction adhesive and screws, put a ledger on the cabinet side and rested the shelf on the window valence. It is very sturdy. The cabinets have solid wood at each corner. This makes a good location for screwing the ledger to the side of the cabinet. Hope this helps Vann
wooleeman
Groupie Joined: 01 Sep 2017 Location: Southeastern PA Online Status: Offline Posts: 80 |
Posted: 17 Nov 2018 at 9:37am | ||
Are the window valances over the bed in a R-179 capable of supporting a wire rack that would be used for some light items such as bedding? If so what would be an easy way to attach without damaging walls or valances?
2022 RP-202
2016 RP-179 (Sold 9/2020) 2014 Silverado Crew Cab. 6-1/2' Bed Golden Retriever (DOB 6/16/2020) English Bulldog (RIP 6/15/2020) |
Ben Herman
Senior Member Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 355 |
Posted: 17 Nov 2018 at 10:09am | ||
No, they are only held in by a few screws with no anchors. I removed the valances on my 179 to allow me to mount the shelf that I built closer to the windows. I use these anchors to secure my shelf. |
wooleeman
Posted: 17 Nov 2018 at 10:15am | ||
Thanks for the info. I really don't want to modify the trailer. I am not sold on the 179 floor plan. I purchased it used to see if I enjoyed camping. Found I do enjoy it but I think I would rather have a 189 in the future and do not want to deter from the resale price. Thanks again.
2022 RP-202
Ben Herman
Posted: 17 Nov 2018 at 1:25pm | ||
Honestly I dont think that adding a shelf or removing the valance will detract from resale, actually I think the opposite is likely the case. Removing the valances (in my opinion) actually looks better than with them on. Just my 2 cents...
Posted: 17 Nov 2018 at 3:53pm | ||
1tulip
Posted: 17 Nov 2018 at 8:49pm | ||
Thanks much for the suggestions. I've got exactly the same shelving. I think I'll do one going port and starboard on the front end over the table and the back over the bed. But I was perplexed about how to keep it from tearing a hole in the wallboard.
Thanks much for the suggestions. |
