Anyone lifted their Pod |
Post Reply | Page 12> |
crankster78
Senior Member Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Topic: Anyone lifted their Pod Posted: 16 Nov 2018 at 8:56am |
Greetings: I don't know about the pods 2016 on, but I had the 4 inch factory block lift kit installed when I took delivery of my 2015 179. I had the same thing done on my first pod, a 2010 171. I haven't had any problem with tail dragging. They are not expensive. Crankster78 2015 R-179
Crankster 78 R-179 2015
marwayne
Posted: 15 Nov 2018 at 6:02pm |
lostagain
Posted: 15 Nov 2018 at 4:31pm |
Thanks StephenH. I already put risers on a couple years ago. They made a big difference getting into the driveway.
But ever thinking of new adventures, I thought it would be exciting to make a run down the Baja California peninsula following the race route, but with our pod and my truck. I don't think I'd enter the race though. Seriously, it would be nice to have that much more clearance for Forest Service roads. I always worry about banging the axle on a rock or something.
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6290 |
Posted: 15 Nov 2018 at 2:16pm |
I think it would be next to impossible to "clock" the existing axle. The brackets are welded on. Cutting them off and re-welding to change the angle and then re-welding would likely do too much damage to the rubber components. The only options are to add a lift kit and if that is not enough, buy a new axle with a different angle.
marwayne
Posted: 15 Nov 2018 at 11:40am |
texman
Senior Member Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
Posted: 15 Nov 2018 at 10:34am |
Coffee guy
It is a 2015 182g. Got the kit from my dealer. $140 I think. I think you can order direct from forest river as well.
CoffeeGuyR190
Newbie Joined: 02 Nov 2018 Online Status: Offline Posts: 11 |
Posted: 15 Nov 2018 at 10:30am |
QUOTE=texman]I added the lift kit. Adds 3.5” I think.[/QUOTE]
What kit did you use? and what year is your Pod?
texman
Posted: 15 Nov 2018 at 10:24am |
lostagain
Posted: 15 Nov 2018 at 9:59am |
I wonder how hard it would be to "clock" the existing axle. Has anyone done it?
GlueGuy
Posted: 15 Nov 2018 at 9:32am |
All the Hood River Edition R-pods have a 2 or 3 inch lift. The later models do this by "clocking" the torsion axles. Earlier versionsput a 2x2 steel block between the axle and the frame.
