  New Posts New Posts RSS Feed: Generator on & off switch after it is running?
Topic ClosedGenerator on & off switch after it is running?
Woody.1 View Drop Down
Direct Link To This Post Topic: Generator on & off switch after it is running?
    Posted: 14 Nov 2018 at 7:14pm
ok, just bought a generator and it as a toggle switch to flip the battery on to start it.
So do I leave the switch on or flip it off? I can’t find anything in the manual.
If I switch off while running it stays running.
It’s a westernhouse iGen 4500 if that matters.
Thanks
wooleeman View Drop Down
Direct Link To This Post Posted: 14 Nov 2018 at 7:45pm
Woody, I looked at a picture of the generator and referred to the manual and I see only one switch. The one that is a push button that shows on/off. The other "T" handle on the top right appears to be the fuel shutoff.  If this is the "switch"  that you are talking about then it will run for a while until the gas in the lines is consumed. I believe you should be able to shut it off by pushing the on/off button or pushing stop on the remote.
2022 RP-202
2016 RP-179 (Sold 9/2020)
2014 Silverado Crew Cab. 6-1/2' Bed
Golden Retriever (DOB 6/16/2020)
English Bulldog (RIP 6/15/2020)
Direct Link To This Post Posted: 14 Nov 2018 at 7:47pm
Sounds a bit goofy. Ours (a Generac) has an "ignition" on/off switch. If it's off, it won't start at all. The starter will crank, but there is no spark.
Our shutdown procedure is to turn off the fuel, and let it run dry. Then I turn off the ignition. I've accidentally left it on for a day or two by accident, and it didn't seem to have any detrimental impact on the battery. I wouldn't want to try it for a month.
Direct Link To This Post Posted: 14 Nov 2018 at 7:58pm
Woody, sorry, I didn't read far enough.  I see your problem now.  That switch is probably there just so the battery is not drained during storage.  You probably should turn it off when storing for extended periods.
2022 RP-202
Direct Link To This Post Posted: 15 Nov 2018 at 9:12am
Thanks for the replies,
I guess after I start it I’ll flip the battery switch off.
Direct Link To This Post Posted: 15 Nov 2018 at 9:25am
I would consider leaving it on in case it might affect the battery recharge. Turn it off when you shut it down.
Direct Link To This Post Posted: 15 Nov 2018 at 9:27am
Yeah that’s kind of what I was wondering if it’s in the off will it not charge the battery.
I’ll keep digging around on the web. I did send Westinghouse an email, but no response yet.
Direct Link To This Post Posted: 15 Nov 2018 at 9:30am
Just monitor the battery voltage while it's running with the switch on and off. If it affects the battery recharge, you should see the voltage go up by a volt or two (depending on the state of charge) depending on the switch. If the switch doesn't affect the battery voltage, you are good to go.
