  New Posts New Posts RSS Feed: simple (I think) electrical question
Topic Closedsimple (I think) electrical question
Ben Herman View Drop Down
Direct Link To This Post Topic: simple (I think) electrical question
    Posted: 10 Nov 2018 at 5:45pm
Hi all - I finished winterizing my Pod a few weeks ago, including pulling the battery and placing it in my shop with a trickle charger. Now my wife wants to open up the slideout so that she can get something out from a storage area that is inaccessible when the slide is all the way in. Will it hurt anything to plug in ac power to the Pod if there is no battery in the unit? And will the slideout work w/ only shore power to the Pod, or does it only run on 12 volt.
My knowledge of the 12 v/shore power system interface is limited and I don't want to end up doing any damage.I know there are many of you with deeper knowledge than me on matters of Pod power systems.
Thanks for the assistance.
Direct Link To This Post Posted: 10 Nov 2018 at 6:14pm
The converter will supply 12V power. An alternative would be to hook your R-Pod's umbilical to your tow vehicle. That way the vehicle will provide the 12V needed to operate the slide without bothering with running an extension cord to the R-Pod.You would not need to fully hitch, just get close enough to be able to plug the connector in to the vehicle's socket.
Direct Link To This Post Posted: 10 Nov 2018 at 6:15pm
Thank you, I had not thought of the TV approach! Thinking inside the box....
Direct Link To This Post Posted: 10 Nov 2018 at 6:17pm
Box? What box? Big smile  Glad I could help.
CharlieM View Drop Down
Direct Link To This Post Posted: 10 Nov 2018 at 6:33pm
The converter may or may not work without the battery. The slide draws a lot of current and usually the battery provides some of it even with the converter plugged in. The TV approach is better or put the battery back in temporarily. If you do try the converter alone be sure the positive battery wire from the camper doesn't accidentally short to the frame.
Direct Link To This Post Posted: 10 Nov 2018 at 6:49pm
Thx - I'll go with the TV option. I was thinking that if I tried it I needed to make sure that the battery leads weren't touching anything, including each other!
GlueGuy View Drop Down
Direct Link To This Post Posted: 11 Nov 2018 at 9:11am
Either way; TV or converter, the positive battery lead needs to be kept away from the frame (as well as the negative lead).
The converter method should work; the converter can supply a lot of amps.
Direct Link To This Post Posted: 11 Nov 2018 at 10:23am
Thank you!
