  New Posts New Posts RSS Feed: Locating the motor transmission housing
Topic ClosedLocating the motor transmission housing
mpraphael View Drop Down
Direct Link To This Post Topic: Locating the motor transmission housing
    Posted: 03 Oct 2018 at 3:19pm
We’re wondering where the motor transmission housing for manual operation of slide out is located. Don’t need now, but in case we run out of juice when we’re boondocking we don’t want to be caught without a slide out that won’t come in. Thanks for your help.
Megan and Peter
Northern Michigan
mcarter View Drop Down
Direct Link To This Post Posted: 03 Oct 2018 at 3:38pm
Have checked on line for Lippert Manuals, lot of info. Search for a Lippert Components In-Wall Slide Out System Owners Manual. It's there I made a copy and have it in my binder.
crankster78 View Drop Down
Direct Link To This Post Posted: 03 Oct 2018 at 5:45pm
Greetings
The slide out is operated by 2 small motors, one on each side that drive gears at the top and bottom. The motors are under the gasket on each side, reached from the outside. To push the slide in by hand the motors need to be disconnected.  Go on line and check out the videos available from the company.
Crankster78
Crankster 78 R-179 2015
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 03 Oct 2018 at 6:34pm
In your scenario, hooking up jumper cables from your tow vehicle to the Pod battery would be a lot easier.
TT
FJ Cruiser
Direct Link To This Post Posted: 03 Oct 2018 at 7:25pm
Many thanks. All helpful ideas!
Megan and Peter
Northern Michigan
