new owner tow setup questions |
arrowhand
Newbie Joined: 26 Aug 2018 Location: florida Online Status: Offline Posts: 2 |
Topic: new owner tow setup questions Posted: 25 Sep 2018 at 6:29am |
wife and I left a deposit for a 2018 180 this last sunday
pickup and walk thru is 10-4-18 I have all ready ordered the trailer brake controller and will get that installed asap have been towing boats in the 17' to 23' upto about 5k in weight for over 30yrs, but this will be the first camping trailer have a 2011 Ram 1500 4x4 with the tow package---have allready added airbags a few years back will i need a weight distribution setup and or sway control thanks for the replys Stacy
Posted: 25 Sep 2018 at 8:30am |
You will know when you hook up. A WDH will assist if the rear of TV is low and front is high, basically a droop at the hitch. I always recommend a sway control, but that's me.
Posted: 25 Sep 2018 at 8:34am |
Arrowhead,
Informative link: http://www.withoutahitch.com.au/caravan/ask-expert-need-weight-distribution-hitch/ |
GlueGuy
Posted: 25 Sep 2018 at 8:37am |
With that truck you technically "don't need" WDH, but many like the altered dynamics with one. We use one with our F-150, and I prefer it when on the road. If I'm making a short haul, I will sometimes not use it. The setup is similar for most weight distribution hitches, and is primarily estimating the amount of weight shifted by measuring fender height at the front and rear of the truck. This is a good video on setup of the E2 WDH.
Posted: 25 Sep 2018 at 8:47am |
Consider also how you will end up loading the rPod and the pickup bed. A wd hitch will partially redistribute the load that's behind the rear axle of the tow vehicle as well as the tongue weight.
The tongue weight on a new empty dry rPod will likely be significantly lower than what you're going to see ready for a road trip. My tongue weight doubled, but I boondock mostly.
Keith-N-Dar
Posted: 25 Sep 2018 at 11:35am |
My F150 came with the heavy duty tow package, and I have never used a WDH. It also says it has sway protection but I have never experienced anything like sway so either it works well or our combo works well. we never load the trailer down in the rear so that may help. Some folks like the ride in the TV better with a WDH. You can't hurt anything by using one.
Keith-N-Dar
arrowhand
Posted: 09 Oct 2018 at 7:18am |
little follow up.
So we picked up our 180 and towed home about 2hrs, put the air bags to about 30psi and very little sag in the rear. Dont think i have any reason to get sway control or a WDH. Cruised down the freeway at about 70mph and it did just fine. For the 2hr drive (50-70mph and flat terrain) the Hemi averaged about 14mpg on the dash display, pretty happy about that.
OldNeumanntapr
Senior Member Joined: 23 May 2018 Location: CA Online Status: Offline Posts: 204 |
Posted: 09 Oct 2018 at 3:14pm |
You probably don’t need weight distribution but sway control is a good investment. My 180 shashayed side to side with only the ball hitch but once I added my Equalizer it was solid and steady.
