  New Posts New Posts RSS Feed: testing battery after powering refrigerator
Topic Closedtesting battery after powering refrigerator
GlueGuy View Drop Down
Direct Link To This Post Topic: testing battery after powering refrigerator
    Posted: 13 Sep 2018 at 9:17am
+1. The battery voltage is a variable value depending on the load. If there is zero load, the 90% value is a fair estimate. If the battery is under load (e.g. the fridge is running on battery), then you might be closer to 100%. You can't really tell the battery State of Charge (SOC) without taking it out of the circuit and letting it rest for a bit. That's typically not practical, so we watch the voltage and "guess" a little bit.
mcarter View Drop Down
Direct Link To This Post Posted: 12 Sep 2018 at 3:46pm
I do that all the time. Appears battery is charging from TV and 12.62 is a good value. The fridge is using battery charge and TV is replenishing.
Happy Tripping View Drop Down
Direct Link To This Post Posted: 12 Sep 2018 at 3:39pm
Hello.
I have a 6 cylinder Jeep Cherokee and propane doesn't work for the refrigerator so I just travelled 2 1/2 hours  running the refer off the battery. After resting, my multimeter says the battery has 12.62 V, which is apparently 90% of the apparent fully charged level of 12.73 V. I say 'apparent' because I don't know nuthin' about this whole subject and I did not test the battery's voltage before I took it on the drive.
The bottom line, is it ok for me to run the refer on battery on 2 1/2 hour long trips or am I incompletely charging the battery and allowing it to run down because the Jeep's electrical system isn't up to the job??
Or, of course, did I screw the whole evaluation up and now have to do it over right?
When not in use, I keep the battery on a trickle charger and the water levels look ok.
