  New Posts New Posts RSS Feed: solar controller mounting
Topic Closedsolar controller mounting
Keith-N-Dar View Drop Down
Direct Link To This Post Topic: solar controller mounting
    Posted: 30 Aug 2018 at 1:24pm
You are right.  But with the range of electrical knowledge we see on this forum I just thought we could avoid the inevitable post about why did I loose all power when I swapped the battery leads.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 30 Aug 2018 at 1:13pm
"It's about 50/50.. just switch the cables at the battery. It's 12v."
The solar cables to the battery.  Not the battery cables.
Yes.. a given within the scope of the question, but yes the 2 smaller cables at the battery are the leads from the zamp port. Just switch them if needed.
Direct Link To This Post Posted: 30 Aug 2018 at 1:04pm
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 30 Aug 2018 at 11:49am
Originally posted by BVK
Originally posted by GlueGuy
The zamp connector should go directly to the battery. You can put the solar controller right at the panel(s), and just extend the battery connection through the zamp connector.
Or you could bypass the zamp connector, and wire your panel/controller directly to the battery.
From what I've read about the ZAMP ports (we don't have one on our 2012 171), the polarity is reversed on the plug, which requires the purchase (or hacking together) of an adapter to correct the polarity.
Does that coincide with your experience?
It's about 50/50.. just switch the cables at the battery. It's 12v..
BVK View Drop Down
Direct Link To This Post Posted: 30 Aug 2018 at 10:03am
2012 RP-171 HRE, 2006 F-150
GlueGuy View Drop Down
Direct Link To This Post Posted: 30 Aug 2018 at 9:25am
oregonkramer View Drop Down
Direct Link To This Post Posted: 29 Aug 2018 at 5:36pm
I just bought the Renology solar panel kit and am trying to figure out where to place the Wanderer controller. I want to use the Zamp connector and though I could splice into the plug line to the battery but couldn't find the route to the battery. Any thoughts are greatly appreciated.
