  New Posts New Posts RSS Feed: Tires for RPod 179
Topic ClosedTires for RPod 179 - Event Date: 16 Aug 2018
john in idaho View Drop Down
Direct Link To This Post Calendar Event: Tires for RPod 179
    Posted: 16 Aug 2018 at 5:26pm
I went one step further and did Load Range E. 80 lbs of air.  Eliminated that tiny side to side sway in the mirrors and the squashed out side walls after a bump.  I think each tire has a load limit of 2600 lbs.  As expected, gas mileage didn't change......  And I had them  balance each one.
And we used trailer tires - the factory had used light truck.
Direct Link To This Post Posted: 16 Aug 2018 at 5:12pm
I also replaced factory C rates with Carlisle D rates - significant improvement in my opinion. Happy I did it. The factory tires were weak in the sidewall, had to much flex and wobble, low pressure rating and load capacity.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 16 Aug 2018 at 4:49pm
Originally posted by TheBum
We've had our Carlisle Trail HD D-load-rated tires on our 179 for ever a year and they've been great compared to the factory cheapies.
What trouble did you have with the factory tires?
2011 R-Pod 177
2010 Ford F-150
TheBum View Drop Down
Direct Link To This Post Posted: 16 Aug 2018 at 3:01pm
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
crankster78 View Drop Down
Direct Link To This Post Posted: 16 Aug 2018 at 1:50pm
I also have the Carlisle radial trail 8 ply load range d on my 179.  I just put them on a few weeks back.  I had the wheel bearings repacked by a local auto repair shop.  The only thing I noticed about them is they seem to have more sidewall flex. So far they look and work well.  They run at 65 psi and have a rated load of 2040 and a speed rating of 80 mph if I recall correctly.  I had them balanced.
Crankster78  R-179  2015
Crankster 78 R-179 2015
mjlrpod View Drop Down
Direct Link To This Post Posted: 16 Aug 2018 at 12:29pm
I use Carlisle Radial Trail 14 inch Load range D tires. I have 2 seasons, and about 12000 miles without any complaints. A reputable tire for a reasonable price.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Kris B View Drop Down
Direct Link To This Post Posted: 16 Aug 2018 at 12:17pm
I have a 2013 RPod 179 with mud tires on it.  235/75R15.   I just want a normal highway tire, what could I replace them with?  Size, brand?  Thanks!
Kris Brown
