  New Posts New Posts RSS Feed: Electrical outlets not working
Topic ClosedElectrical outlets not working
JAKLEMO View Drop Down
Direct Link To This Post Topic: Electrical outlets not working
    Posted: 03 Aug 2018 at 11:15am
We are out camping in our 2018 our pod 189. We have a generator going and the microwave is working the refrigerator is running on battery the water pump and water heater are both working however none of my electrical outlets are working. I can turn on the air conditioner and within a matter of a minute the generator dies. I am assuming the generator is not powerful enough to run the air conditioner. Why are my electrical outlets not working though?
Direct Link To This Post Posted: 03 Aug 2018 at 11:21am
What is the status of your ac breakers?  What is the capacity of your generator?  Are you trying to run a bunch of ac appliances while the ac is turned on?  It is not likely your fridge is running on battery if you have the generator turned on.  If it's running on battery, your batteries are going to be discharging pretty deeply and very fast.  Better to turn your fridge to gas.
ZuBrew View Drop Down
Direct Link To This Post Posted: 03 Aug 2018 at 11:35am
I have a 2018 189.  Check these breakers inside the converter to make sure all are on.
2017 Chevy Silverado 1500 4X4
2018 R-Pod 189
2013 Yamaha FJR 1300A
Larry-D View Drop Down
Direct Link To This Post Posted: 03 Aug 2018 at 11:53am
It the breakers are "on", remove the inner panel and make sure the electrical connection of the wire to the breaker(s) is tight.
Direct Link To This Post Posted: 03 Aug 2018 at 12:20pm
Breakers are on. Will check the inner panel in a bit. Will switch the refrigerator to gas too. Thanks. I’ll let you know what happens.
Direct Link To This Post Posted: 03 Aug 2018 at 12:22pm
There was nothing else running off of the generator, and none of the electrical outlets were working. But I will try the above mentioned things in a bit. We are not at the trailer right this second.
TheBum View Drop Down
Direct Link To This Post Posted: 03 Aug 2018 at 12:26pm
I'm surprised nobody has mentioned the GFCI yet. It may need to be reset.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
CharlieM View Drop Down
Direct Link To This Post Posted: 03 Aug 2018 at 12:30pm
Check the status of the Ground Fault Circuit Interrupter (GFCI). This will be an outlet with two buttons on it. If it is tripped it may affect all the other outlets. Wiring of the RPODs is very inconsistent. Sometimes all outlets are wired through a single GFCI outlet.
Forest River's Motto: Let no two Pods be built the same.
Direct Link To This Post Posted: 03 Aug 2018 at 12:45pm
Would it affect all the outlets in the trailer if the gfci is tripped?
Direct Link To This Post Posted: 03 Aug 2018 at 12:56pm
Yes. Check the GFCI. Happened to us at least once.
