  New Posts New Posts RSS Feed: Removing front decal
Topic ClosedRemoving front decal
Old Surfer View Drop Down
Direct Link To This Post Topic: Removing front decal
    Posted: 31 Jul 2018 at 3:36pm
Does anybody know the best way to remove the big "R-Pod" decal?
I've tried to use a razer blade but it comes off in 1/4" pieces. My cat has scratch it all up trying to get on top.
Rick and Melanie
2008 Tundra CrewMax 4-Wheel Drive
2015 R-179
Surfer
Direct Link To This Post Posted: 31 Jul 2018 at 3:52pm
Have read in past posts of individuals using a hair dryer on the decal which softens the adhesive so that you can peel it off.
mcarter View Drop Down
Direct Link To This Post Posted: 31 Jul 2018 at 3:57pm
+1 - I'd be careful with a razor blade. You can nick the surface. Heat it and use a hard plastic scraper. Once you get the decal off, you can use several available products to remove excess adhesive.
Direct Link To This Post Posted: 31 Jul 2018 at 4:02pm
Thanks for the info. I'll try it when it get a little cooler. Maybe in the morning.
Rick and Melanie
2015 R-179
Surfer
harrypodder View Drop Down
Direct Link To This Post Posted: 31 Jul 2018 at 5:51pm
I would make a quick call to the factory customer service. I'm sure they have had some decals that needed to be removed and could tell you what is safe to use without damaging the surface. If you get an answer please post it since it seems 80% of a Pod is decals it would be helpful.
Presitla99 View Drop Down
Direct Link To This Post Posted: 31 Jul 2018 at 7:49pm
Mine peeled off in one piece after sitting in full sun for 3 hours.
