Tomcheryl ![]() Newbie ![]() Joined: 24 Apr 2018 Online Status: Offline Posts: 16 |
![]() Posted: 04 Jul 2018 at 4:03pm |
Ohhh ok thanks again guys!!
Cheryl Now to post a new thread on dead battery ☹️ |
Life is short,it’s time to roll
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6434 |
I was in West Yellowstone. We were in town but even with the booster, we only got enough of a signal on one channel to know it was there. However, it was unwatchable. I agree that it is in the availability and strength of the signal that are primary factors in whether you can get TV reception or not.
Unfortunately not the proximity of town, more the availability of signal.
thanks!!!!! I had changed the source last night while the DVD was playing and it didn't work, BUT I tried again this am without the DVD and we have COLOR!!!! THANK YOU! My Grands would have been thrown into a time warp. Still no signal, booster is on. we are at the Pangutich KOA UT its real close to the town. so I figure the reception should be good.
Awchief ![]() Groupie ![]() ![]() Joined: 04 May 2018 Location: Biloxi, MS Online Status: Offline Posts: 83 |
Set source to “AV”.
Michael
You are set to the wrong source.
For the television, are you trying in an area with good reception or bad reception. Did you turn the TV's amplifier on (the button on the wall plate). Did that make any difference? I remember reading about the black and white and how to fix it. It has been a while but a search might find the posts on that subject.
Hello we have a 179 2016.5 …. we have only used our TV several times in the past year, I just tried it to watch and is says no signal.... ok ill watch a dvd...it worked but the picture is in BLACK and WHITE???? any suggestions. On our way to pick up the grands and we {they} need color TV. I tried messing the settings but no luck. TIA Cheryl
