  New Posts New Posts RSS Feed: Preventing Battery Drain
Topic ClosedPreventing Battery Drain
GlueGuy View Drop Down
Direct Link To This Post Topic: Preventing Battery Drain
    Posted: 16 Jun 2018 at 8:45pm
Originally posted by Abercrombies
Thanks!👍🏼 What about the fridge? What setting should it be on when not using?
Not sure what you mean? If you're not using the fridge, then turn it off. If you are boondocking, then generally use the propane. If you have full hookups, then dealer's choice; we use AC when we have a full hookup.
Abercrombies View Drop Down
Direct Link To This Post Posted: 16 Jun 2018 at 8:41pm
"better than we deserve!"👍🏼
¯\_(ツ)_/¯
RPOD-189
GMC Pickup
Bruce & Linda
Direct Link To This Post Posted: 16 Jun 2018 at 8:37pm
Unless your TV has an automatic disconnect, then, for sure, you should unplug the 7-pin to prevent the TT from draining your TV battery.
Direct Link To This Post Posted: 16 Jun 2018 at 8:09pm
Parking our Pod while connected to the tow vehicle is draining the battery on our truck. We have nothing on or running in the trailer? Should we disconnect the trailer brake cable?
¯\_(ツ)_/¯
RPOD-189
GMC Pickup
Bruce & Linda
