Topic: Another brake problem Posted: 08 Jun 2018 at 5:56pm |
Igblau could do that if he wants on one wheel. Pull the tire and wheel on one side. Use a 1/4 spade jumper with a fuse. Jump from the 11 to 7 positions on the 7 pin as you look at it, with the alignment lug on top (12) position. The brake should push the shoes out to contact the hub. The hub should be hard or impossible to turn by hand. If not the shoes are not contacting the hub.
Posted: 08 Jun 2018 at 6:15pm |
Just so we are on same page. When the hub is pulled and bearings replaced the brakes stay with the backing plate. There is no reason to mess with the brakes. The bearings, races and seals are all in the hub. The only reason to be on the backside of the backing plate would be to release the star adjust to let hub off easier, that's it. Nothing in relation to brake to assemble wrong, just the hub and bearing components and you can jack that up but brake still works.
GlueGuy
Posted: 08 Jun 2018 at 8:03pm |
Originally posted by mcarter
Just so we are on same page. When the hub is pulled and bearings replaced the brakes stay with the backing plate. There is no reason to mess with the brakes. The bearings, races and seals are all in the hub. The only reason to be on the backside of the backing plate would be to release the star adjust to let hub off easier, that's it. Nothing in relation to brake to assemble wrong, just the hub and bearing components and you can jack that up but brake still works. |
I know, but I was trying to search for a cause and effect. You shouldn't have to open up the brakes at all for a bearing re-pack, but something went wrong here.
lgblau
Posted: 08 Jun 2018 at 9:41pm |
The brake guy simply took the wheel and drum off, and looked to see if the bearing pack was done. He said everything that he was supposed to do was done. What could I do. It was my word that the brakes were good before the repack. I have an appointment Tuesday at a shop thst builds trailers. Again, Thanks.
Leonard🌵
2017/179
2017 Ram 1500
lgblau
Posted: 09 Jun 2018 at 9:34am |
Thanks again for all the information, and I know you are all trying to help, but it’s still something that I can’t deal with. I will let you know what the trailer specialists do to fix it.
Leonard🌵
2017/179
2017 Ram 1500
Posted: 09 Jun 2018 at 3:39pm |
It's cool Leonard, interested in what they find. Sometimes I talk to much, but I'm a brake guy:)
lgblau
Posted: 09 Jun 2018 at 4:51pm |
That’s okay Mike. I am interested in the topic, but just don’t get it. My older brother was a master electrician (RIP).
Leonard🌵
2017/179
2017 Ram 1500
lgblau
Posted: 12 Jun 2018 at 11:42am |
Okay, Fixed. Actually it was quite simple. The brakes were out of adjustment. The original mech said he did not touch the shoes. NOT SO. Thanks again for the support.
Leonard🌵
2017/179
2017 Ram 1500
Posted: 12 Jun 2018 at 2:21pm |
Zactly. He adjusted them in to allow drum removal and didn't adjust back. Guaranteed.
lgblau
Posted: 12 Jun 2018 at 2:53pm |
Leonard🌵
2017/179
2017 Ram 1500
