  New Posts New Posts RSS Feed: Fridge beeping on shore power
Topic ClosedFridge beeping on shore power
TheBum View Drop Down
Direct Link To This Post Topic: Fridge beeping on shore power
    Posted: 23 May 2018 at 11:15am
Originally posted by mcarter
Bum, when plugged into shore power do you keep the fridge on all the time? Turn the fridge off for a day, open the door, let it cool down. Maybe issue with door switch and condensation. I keep my Pod plugged in 24/7, but not with fridge on.
I'll give that a try. I don't usually keep it on, but we didn't get it completely emptied after the last trip, so I left it on at a low (less cooling) setting.
However, wouldn't it do the same thing on battery if that was the case?
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 22 May 2018 at 7:40pm
+1 with Mike.
mcarter View Drop Down
Direct Link To This Post Posted: 22 May 2018 at 6:48pm
Larry-D View Drop Down
Direct Link To This Post Posted: 22 May 2018 at 6:43pm
Sounds obvious but I found mine doing the same thing, turned out to be I didn't have the door shut good.  Hopefully that's it and no more.
Direct Link To This Post Posted: 22 May 2018 at 5:31pm
We keep our R-Pod plugged into shore power all the time it's in storage. I had to go out to get something and was greeted with a flashing warning light and a flashing shore power light on the fridge panel.
I checked the GFCI and it was not tripped; I even plugged something into an outlet to make sure. The breakers were all on except the one for the microwave, which I had turned off intentionally. I even turned it on to be sure. When I switched over to battery, the fridge seemed to run fine: I didn't get any warning lights and I heard the converter fan kick on.
Am I likely looking at a control board replacement, or is there something else I can look at?
Thanks.
Alan
Three cats
