  New Posts New Posts RSS Feed: Water
Topic ClosedWater
Direct Link To This Post Topic: Water
    Posted: 23 May 2018 at 8:48am
I'll add a little more to that. We have (had actually, sold it last year) a utility trailer that when full weighs as much or more than our R-pod. However, it is very low profile. The mileage we get pulling that utility trailer is at least 30% better than what we get pulling our R-pod. So the weight matters, but not nearly as much as the wind resistance. I think about 50 lbs of water in the water heater and think... meh.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 23 May 2018 at 7:52am
Originally posted by lgblau
Everyone, evidentially, missed the whole idea that I was relating to. It had nothing to do with the operation, and or maintanance of the water heater. I simply asked if anyone drained their tank to save on the weight. Sorry if I somehow confused my post. 😎
We did go off on some tangents, but I think we mostly got your point and the answer is no, no one worries about that extra 50 pounds.  It makes no discernible difference to your MPGs and if you are calculating your weight with regards to your towing limits that carefully, you should probably be looking for a larger TV.
I was listening to Click and Clack, the Tappet Brothers, once when a listener asked whether driving with your headlights on (during the day) caused one's gas mileage to go down. His brother insisted it would.  Of course the Magliozzis laughed and said no, but then they got into one of their "yeah, but" discussions.  They allowed as how there is no such thing as a free lunch and yes, the extra electrical load on the alternator would cause the engine to use slightly more power (= gasoline).  Short of some big fancy MIT white board calculations though, they guessed that 2 identical cars driving across country, one with lights on and the other off, assuming identical driving conditions, etc., the car without lights might use a dollar less in gas.
50 pounds of water would probably cost more than leaving your lights on, but still, it would take a pretty sharp pencil to calculate how much more.  If your time is worth anything, you probably aren't going to come out ahead draining the water heater.  And you could end up spending more on Teflon tape than you'll save on gas.
Direct Link To This Post Posted: 23 May 2018 at 7:24am
Igblau,
Nope I don't drain water heater. Actually that 6 gals of water could come in handy. You can use the water pump and take water from hot side for emergency purposes. Won't be hot, but who cares.
Direct Link To This Post Posted: 23 May 2018 at 1:20am
Wind resistance is a much bigger factor than the approximately 50 lbs of water in the water heater. I agree that leaving it full is best. Quantity of water in the fresh water tank is a different question as to the amount to carry. We travel with a full FW tank since we do tend to stay at places without hookups while we are enroute to a destination.
lgblau View Drop Down
Direct Link To This Post Posted: 23 May 2018 at 12:10am
Leonard🌵
2017/179
2017 Ram 1500
Direct Link To This Post Posted: 22 May 2018 at 7:52pm
We are still using the same anode rod that came on our 177 when we picked it up March 2011, so it is now over 7 years old, almost looks like new.  Maybe because it has never seen municipal water with all the added chemicals, Our 177 has the FW tank in the rear, nevertheless we always leave with it full of delicious well waterl unless we are only going for a couple days, then 1/2 full is more than enough.  Thanks to furpod we got on a semi - regular track for sanitizing our FW tank.  Did it the first year we owned it and then went over 4 years before we did it again,  Now we  try to sanitize 1x/year just to be safe.
Once we put water in our HW and FW tank which is usually late April or early May, it remains in the tank until we winterize in November.
Direct Link To This Post Posted: 22 May 2018 at 7:39pm
+1 with Tars
Direct Link To This Post Posted: 22 May 2018 at 7:08pm
I agree regarding the anode.  Looking at it once a year is plenty.  I can't remember the last time I checked the anode rod on my water heater at the house. The water heater will function fine without an anode rod -- though it will probably last longer with one.  Point being, if you check the anode once a year and it's gone when you check, you aren't too late to replace it.
Direct Link To This Post Posted: 22 May 2018 at 6:26pm
Well, flat6s, you're the one. That anode rod will change by season, not trips, however you be using some really bad water. What ever floats you're boat, it's your Pod.
flat6s View Drop Down
Direct Link To This Post Posted: 22 May 2018 at 6:09pm
I drain my hot water tank after each trip.  Gets me a good look at the anode. Also gives me a chance to clean out all of the debris in the bottom of the Hot water tank.
