'bathroom' works kitchen sink doesn't |
Post Reply | Page <12 |
Jenga Jack
Groupie Joined: 12 Apr 2016 Location: Southern Oregon Online Status: Offline Posts: 57 |
Topic: 'bathroom' works kitchen sink doesn't Posted: 13 May 2018 at 6:40pm |
2014 R-Pod 178 aka the "Kobra Pod"
following a 2015 4Runner wherever it may wander |
Jenga Jack
Posted: 13 May 2018 at 6:42pm |
Wow! I just de-winterized and had the same issue as Happy Tripping. Shower/toilet worked fine, trickle from sink faucet. I thought o-oh, now what have I done? Before the cuss words came out, I thought I'd check the R-Pod Forum. Yup, someone had the exact same problem. Reading the possible cures, I tried the easiest one first and TA-DAH! Problem solved!
R-Poders, you all rock! Happy camping!!
Ben Herman
Senior Member Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 355 |
Posted: 13 May 2018 at 6:47pm |
Also worth unscrewing the aerator/filter at the end of the kitchen faucet. Mine was clogged and causing reduced flow.
cgarb
Groupie Joined: 27 Mar 2011 Location: California Online Status: Offline Posts: 95 |
Posted: 04 Jul 2018 at 12:12pm |
We are getting our pod ready to sell and are checking out all the systems. Since we dry camp, we never use the water system and discovered that after a short spurt of water nothing came out of the faucets. I followed you advice and took the kitchen faucet apart - lots of calcification! All kinds of grit clogged the screen of the faucet. Washed that out and ran the water for a bit and it is fine. The hot water faucet in the bath works, but not the cold. I couldn't find a way to open it up enough to clean it. Do you have to take off the whole panel around those faucets, taking out the caulking and hoping not to damage the wall? Or is there another way to get in there?
Thanks!
Carol
177 HRE rpod 2014 Honda Pilot |
brandtjm
Newbie Joined: 27 Jun 2020 Location: Colorado Online Status: Offline Posts: 8 |
Posted: 26 Jul 2020 at 1:23pm |
I found the screen on my faucet completely blocked. Once cleaned it worked just find.
Jeff B
Posted: 26 Jul 2020 at 2:22pm |
This could get messy. I'm not familiar with the 177's layout. Can you access the back side of the faucet? If so, try removing the water line (turn the pump off and release all pressure first) and see if you can then force some air through from the front side to blow out any crud that is in there. If you don't have a compressor, a can of compressed gas duster such as Dust Off should suffice.
