Podizzi
Calendar Event: No water kitchen sink Posted: 18 Apr 2018 at 8:55pm |
Just set up at camp sight with no hook ups. Running off battery and generator. No water at kitchen sink, cold or hot. The water pump runs as the water in bathroom works. Any ideas on a fix? I have a 2017 rpod 179. Thanks!
Podizzi
2017 rpod 179
2016 Toyota Sequoia
Phoenix, AZ
GlueGuy
Posted: 18 Apr 2018 at 9:05pm |
Check the aerator in the faucet. Happened to us a few times when the pod was new. Little itty bitty grains of sand were clogging it.
lostagain
Posted: 18 Apr 2018 at 9:20pm |
+ one.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Tars Tarkas
Posted: 18 Apr 2018 at 9:31pm |
99.9% aerator. I leave ours off.
TT
FJ Cruiser
Podizzi
Posted: 18 Apr 2018 at 11:13pm |
That fixed the problem. Thank you very much,
Podizzi
2017 rpod 179
2016 Toyota Sequoia
Phoenix, AZ
Tars Tarkas
Posted: 19 Apr 2018 at 7:38am |
Thanks for letting us know it's fixed. Glad it was so easy.
TT
FJ Cruiser
Capt Kidd
Posted: 19 Apr 2018 at 11:16am |
So I cleaned the areator and hot works very good but cold is only half half the volume. I am hooked up to shore water with out the water pump on. Any ideas?
The Pirate's Pod
Larry-D
Posted: 19 Apr 2018 at 2:05pm |
Do you have the same pressure difference with the shower? If not I'd pull the faucet when you get home and take a look.
lostagain
Posted: 19 Apr 2018 at 5:38pm |
Debris in the cold water line that got hung up in the valve? You may want to get a bucket, disconnect the cold water line from the sink, put a bucket in a position to catch the water, turn the pump on to push some water through. If it flows ok, then the blockage may ben in the faucet. Take it apart and see if there is something stuck in the valve.
Sonoma 167RB
Our Pod 172
