Need help sanitizing |
Post Reply | Page 12> |
henryv
Senior Member Joined: 09 Feb 2017 Online Status: Offline Posts: 259 |
Topic: Need help sanitizing Posted: 06 Mar 2018 at 6:46pm |
I'm sanitizing my camper. I put bleach in the water and letting it sit overnight. Tomorrow I will let it drain out. I want to go for a trip but I want the tanks empty and clean. Can somebody advise me. When you hook up to the city water and fill it from the house, do you need to use a filter? Where does the water from the sink and bathroom go, to the black tank? Do you have the water pump switch on anytime you use water? How do I flush out the black tank? It's a 2016 171 and I think this is the first time. Also how do I know the hot water tank is full before I turn it on, how do I turn it on, I know there is a switch outside.
Posted: 06 Mar 2018 at 7:28pm |
Water from the bathroom and kitchen sinks go to the Gray water tank. The toilet goes to the Black water tank.
A pressure limiter (check Walmart's RV equipment or online for one) is needed to make sure you don't overpressure and blow out one of your water lines if you are using city water. The limiter will limit the pressure to about 50 psi, which is safe for RV water lines. At the same time, you can pick up a filter, either single pack with flexible fitting or double pack. For water to flow from the fresh water tank, you do need to use the pump to provide pressure. If you are connected to city water, you don't need to use the pump. How do you know the hot water tank is full? Simple, turn on a hot water tap. If it is sputtering air or air and water, the tank is not full. If you have a good flow without air, then the tank is full. This is provided that you changed the bypass valve(s) to not bypass the tank. One way to make absolutely sure is to open cover on the outside and then open the valve on the hot water heater. If there is water flow and no air sputtering out, then it is full. As for turning it on, for electric, use the switch outside. For propane, the switch is inside. It should be on the same panel as the switch for the water pump. Flushing black water tank: hook hose to connection on outside. When you turn the hose on, the water will spray inside the tank to help flush things out. Remember that it is a flush so you don't want to keep adding water without the drain being open or you risk filling it so much that you get a stinky brown fountain from the roof vent. That would not be a good thing. |
Leo B
Posted: 06 Mar 2018 at 7:34pm |
"Flushing black water tank: hook hose to connection on outside. When you turn the hose on, the water will spray inside the tank to help flush things out. Remember that it is a flush so you don't want to keep adding water without the drain being open or you risk filling it so much that you get a stinky brown fountain from the roof vent. That would not be a good thing. "
henryv
Posted: 06 Mar 2018 at 7:44pm |
So there are 3 tanks? black, gray and fresh? how much does each hold?
Leo B
Posted: 06 Mar 2018 at 7:54pm |
Fresh- 36 Black- 30 Gray- 30
Posted: 06 Mar 2018 at 8:16pm |
Fresh: 30 gallons in tank plus 6 gallons for hot water heater or 36 gallons total
Black and Gray: 30 gallons each There is a little more in the lines, but there is no measurement posted for those. |
henryv
Posted: 06 Mar 2018 at 8:46pm |
What is meant by "city water"? water from the house spicket? There are two places for water, explain how to use each. I know the top one fills the tank, and the lower one is city water whatever that is...
Posted: 06 Mar 2018 at 8:58pm |
You got it right. The big opening is to fill the tank. The one to which you can attach a hose from a spigot is the city water connection (even if it is from a well pump for naming purposes). Please use a drinking water safe hose to fill the tank or connect to city water. That is not your typical green garden hose which might contain chemicals that are not safe to drink.
SC for Huskers
Senior Member Joined: 22 Feb 2017 Location: Goose Creek, SC Online Status: Offline Posts: 144 |
Posted: 06 Mar 2018 at 10:41pm |
The other day I flushed the antifreeze out and when done, hit the switch on water pump. Nothing happened. Is there a level safety switch, or do I have a problem?
Thanks in advance. |
Happy Traveling,
Tom 2017 172pod 2011 F150 STX |
henryv
Posted: 07 Mar 2018 at 5:25am |
So does the city water go into the tank, or bypass it?
