Power cord pulling out |
Happy Tripping
Topic: Power cord pulling out Posted: 01 Mar 2018 at 10:19am |
In hopes my experience will benefit others - I do loop it once around the vertical tongue jack in order to shorten it so that there is less 'slack' to it. It seemed like a good idea at the time. The problem appears to be that the cord is stiff when cold and lacks the ability to flex under pressure.
I hate to see it drooping down to catch on something and could see using zip cords or electric tape to shorten it and fasten it down, but is this necessary? |
Posted: 01 Mar 2018 at 10:25am |
If it is fully plugged in, there is a tab over which the cover of the receptacle should hook. That keeps it from being pulled out. As for hanging down, as long as it is not in danger of dragging, it should have sufficient slack to allow for turns. If you have it too tight, when you turn, there is no alternative but for it to pull out. I have not shortened it and have never had it pull out. But if you are concerned, figure out a way to use a bungee cord to support it in the middle so it can flex as needed and still be supported. After all, you don't always tow it in a straight line.
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2628 |
Posted: 01 Mar 2018 at 1:06pm |
+1 to what Stephen is saying. You do need some slack to allow for turning, but you don't want it dragging either. The tab should be held by the cover; unless it's pulled on really hard, it should not come out.
lostagain
Posted: 01 Mar 2018 at 2:58pm |
If you have enough length and it's still pulling out, you might put a wrap of black plastic electric tape around the plug and the spring loaded cover that has the tab on it mentioned by StephenH. It may be that the spring tension is a little weak and it's not enough to keep the little tab engaged on the plug. The tape is cheap, easy to remove, and quick to put on. You may want to also investigate whether you can replace the spring on the plug cover on your TV.
coopercdrkey
podders Helping podders - pHp Joined: 26 Aug 2012 Location: Cedar Key, FL Online Status: Offline Posts: 457 |
Posted: 01 Mar 2018 at 5:23pm |
I wish I had an easy solution- I don't, without being able to see the situation in person- but I have a word of critical advice-
Figure it out and fix it! More than the wires to your lights is involved. Your trailer brakes are actuated through the same connector. Very bad to lose trailer braking. Suggestion- Don't loop the cable. Let it sag. Insert the 7-conductor plug firmly, as you have been doing, and lower the cover to latch the plug. Then take a sturdy zip fastener and cinch it up tight around the cover and plug. This might help insure the tab stays locked by the cover.
Bob and Joyce
Jennifer and Baxter, the Campin' Cocker Spaniels RP 177 "Key Pod" Chevrolet Silverado 1500 LT / Z71 |
Leo B
Posted: 01 Mar 2018 at 5:27pm |
+1
dr2428
Groupie Joined: 13 Aug 2016 Location: Nebraska Online Status: Offline Posts: 70 |
Posted: 01 Mar 2018 at 5:57pm |
I had difficulty getting my power plug to stay seated due to a difficult to reach location under the bumper. The plug does "snap" into the plug cover but I didn't trust it initially so I used a zip tie to fasten the cord to the hitch bar going into the receiver, of course leaving more than ample slack for turns. This minimized the pull, or weight of the rest of the cord on the the plug. I've since gained confidence in the connection but do this anyway with a velcro strap just because I like it that way.
Good luck |
2017 RPod 179
2018 Chevy Colorado Z71 4x4 |
rda54
Senior Member Joined: 18 Nov 2016 Location: Minnesota Online Status: Offline Posts: 106 |
Posted: 01 Mar 2018 at 6:50pm |
I had the same problem and I replaced the end because it would not stay in. Now it works great.I don't like being without lights or brakes.
Ronald & Lonna
2014 178 2016 Chevy 1500 |
