  New Posts New Posts RSS Feed: WFCO power converter fan
Topic ClosedWFCO power converter fan - Event Date: 02 Feb 2018 - 03 Feb 2018
jonskipro View Drop Down
Direct Link To This Post Calendar Event: WFCO power converter fan
    Posted: 02 Feb 2018 at 10:45am
Why does my fan WFCO converter fan continue to run when I have power connected to the R-Pod 179.
Jon M
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 02 Feb 2018 at 11:11am
It runs when the load on the converter is sufficient to need cooling. As far as I know since the converter is not active except when the Pod is on shore power the only time it will run is when the Pod is plugged in.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 02 Feb 2018 at 11:46am
Jonskipro,
Does it run all the time? Never shut off? That could indicate a continuous load. I would do some battery checks, make sure battery is not constantly charging with all 12V accessories off. Also make sure fan is clean, no pet hair or debris, that could make cooling difficult and fan running. My first action would be to look at battery and charging.
Direct Link To This Post Posted: 02 Feb 2018 at 11:49am
Originally posted by mcarter
Jonskipro,
+1. The fan on ours runs for an hour or two or three, depending on the SOC of the battery. Once the battery(ies) is/are charged up, the fan goes off.
Direct Link To This Post Posted: 02 Feb 2018 at 12:01pm
+2. Ours runs when first plugged in, but stops when the battery charge state is sufficient.
One question: Are you perchance running your refrigerator on battery instead of AC when plugged in or on gas when it is not plugged in? Plugged in, that would put a constant load on the 12V system which would keep your converter working hard to supply the demand. If it is after you tow, then your TV may not be supplying sufficient current to both run the refrigerator and charge the battery/batteries adequately. That would mean it would have to work longer when it is finally plugged in to get the battery/batteries charged.
Direct Link To This Post Posted: 02 Feb 2018 at 8:35pm
Thanks everyone, very helpful.....
Jon M
