amnman
Topic: Lithium battery? Posted: 21 Aug 2018 at 10:02pm |
Last a lot longer than those GC batteries.... life wise.... so cost goes down significantly.
So far my battery has made boondocking so much more enjoyable. My solar system works great as well.
Be responsible with technology, or technology will make you irresponsible. ~ Me
GlueGuy
Posted: 05 Jun 2018 at 10:22am |
Originally posted by amnman
It is a 4 cell battery.... The standing voltage is 13.9 after the converter stops charging (14.4 when charging). The voltage after running my ice maker was 13.5. My water pump works better... more stable pressure. All the 12v systems seem to be fine and the lights didn't dim when the ice maker's compressor turned on. The battery can be run down to 90%, but the voltage will drop quickly after this.... so 95% is usable. Discharge rate is 1C (100Ah) for 55 minutes... but this discharge rate will shortens its life.
That's good info. That means that a 100AH Lithium will get you something in the neighborhood of 1250 watt-hours of power, whereas a 100AH lead acid will only get around 600 watt-hours (lower voltage and less discharge tolerance). What it means to me is that a single 100AH Lithium has almost as much power as a pair of 6V GC batteries.
amnman
Posted: 04 Jun 2018 at 8:59pm |
GlueGuy
Posted: 28 May 2018 at 12:14pm |
That's an interesting mod. I think in the next year or so the cost of lithium batteries will drop significantly, so you may be ahead of the curve.
I'm curious. A standard LiON battery voltage is ~~ 3.6 volts. 3 cells in series would get you 10.8 volts, but 4 cells in series would get you 14.4 volts. I wonder what the idle voltage of your battery is? Or do you know how many cells your battery is?
I'm also curious what percent discharge your lithium battery can handle? Typical lead-acid is only 50% discharge (wet cells). How low (percent-wise) can your lithium handle?
amnman
Posted: 27 May 2018 at 7:07pm |
Today, I just converted my Lead acid battery system on my R-pod 171 to lithium battery.
Components: 1 Battleborn Lithium battery 12v 100aH $949 (w/ free shipping) 1 Progressive Dynamics Converter modification for my WFCO power system $235 (includes shipping) 2 ANL fuse holders $14 ($11 for a 10-pack of 100A fuses) 2 24" 5AWG cables with ring terminals (5/16") already installed $11 1 Group 31 battery box.
Took me 1/2 a day to install. Longest period was installing the converter mod. You replace the DC board and swap the wiring/fuses to the new DC board as well as the battery cables. Then remove the converter power circuit board and replace it with the new one.
The fuse/fuse holders and cables are attached to the battery. The cable from the RV are attached to the fuse blocks for additional safety. 100ah Lithium battery can send 200 amps for 30 seconds, enough time to start a fire with a short, so the fuses will give at 100 amps.
So I guess you are wondering why I did this? Well for something simple as "creature comforts" My ice machine and 1Kw pure-wave inverter could kill a 100aH lead acid battery w/ solar charging in less than 3 hours (voltage alarm goes off) before filling the basket.
I setup the lithium battery (charged) with the same inverter and ice maker, I can fill the basket TWICE and still have power left over. Took my 200w solar charger and reprogrammed it for Lithium. The charger is a Victron MPPT 75/15 using battery clamps for a battery connection. After peaking the solar panels every 1/2 hour, the solar system recharged that battery in 6 hours.
So I bought all the other components needed to install this in my R-pod and the rest is history.
Olddawgsrule
Posted: 08 Feb 2018 at 4:22pm |
Originally posted by RobnCari
Isn't gasoline a hazardous material. Certain states won't let you pump your own. |
First I see you pull with a Tacoma! I will be as well! Work good for you?
Back on topic: Yes, gasoline is. So if you carry 'Jerry cans" you will be looked at. You're allowed so much (would have to look it up again) and same for the propane we carry.
My concern is tongue weight so I will carry an additional propane bottle in the bed of the truck. This is allowed, as I've read.
Li-ion batteries are still kinda new. Considered hazardous if not done correctly. Since still new, was curious if those using have been asked as of yet. So far, I'm seeing no one has been.
RobnCari
Posted: 05 Feb 2018 at 9:55pm |
2006 Toyota Tacoma 4WD AC
2018 RP 179
Olddawgsrule
Posted: 03 Feb 2018 at 7:39am |
Thank you all! Very good info.
ParPod
Posted: 02 Feb 2018 at 4:29pm |
Have been back and forth across the border numerous times with the Pod - never been asked about batteries. We've had USCBP in the Pod twice - Michigan and North Dakota - and both times they were far more concerned about various food things. Insofar as CBSA coming back home they've never asked or shown much interest in the battery box or what kind of battery is inside.
Bob&Margaret
2017 179
2016 Toyota 4Runner
2 sets of Golf Clubs
Pod People
Posted: 29 Jan 2018 at 6:21am |
We have traveled into Canada 3 times with the pod. We were never asked about batteries.They asked about weapons, alcohol, fruits and vegetables, passports and vehicle registration and insurance.
From what we saw, I don.t think you will have any problems with batteries. Vann
Vann & Laura 2015 RPod 179
