wall studs?? |
lostagain
Topic: wall studs?? Posted: 17 Jan 2018 at 12:18pm |
When I raised the bed on our 172, I left the 1x2 supports along the wall from the old bed in place and ran 3 vertical supports up to the new bed supports that I put along the walls above. It was more than adequate to carry the weight. I also ran a solid piece of pine along the front with a width equal to the additional height of the bed. On the front wall I also left the original bed support in place and ran little "legs" up to the new support that I screwed onto the wall. I also had to extend the support for the bed base where it's hinged as the raising of the bed made it wider, using the same concept of little legs from the new base to the old one.
It's been more than sturdy enough and the wider bed is a more comfortable for me and my wife. It's almost as wide as a standard double bed. And the additional storage below is a plus.
voisj
Posted: 16 Jan 2018 at 9:43pm |
Elkcamp, I've been all over this one on my 180. The 180 model lends itself to so many mods! To find studs I use a high quality stud finder, or on any cold morning and you will see them in the condensation on the outside (on the shady side) Be aware that the aluminum studs are only 1/16" thick and you will need an anchor of some type to get real grip. But you really don't need to attach to the studs just use blocks to tie the 2 frames together, The plywood on top keeps things tight. I used small 1" L brackets to attach the frame together. In the 180 bed area there is a stud 4" forward of the front windows on either side. And one lined up with the back of the window. You can see in this picture after the plywood is off where they screw the cleats to the walls But they didn't line them up with the vertical studs, there may be horizontal studs where they screwed it to the walls. If you are raising the mattress like this.You can see I used blocks to tie the old frame to the new frame, under the window. ( The plywood below was removed after I discovered it wasn't needed ). To See my post on the project, follow the links in my All my 180 mods post, 2nd mod down page 1. Plus there are more pictures of the under bed framing in the links to the twin bed mod. This project was to add drawers under the mattress.(Not enough storage in the 180) But now it looks like this. Congrats on the new 180! these things are a blast. Cheers, John |
Leo B
Posted: 16 Jan 2018 at 6:54pm |
Love those old vans!!!
Posted: 16 Jan 2018 at 6:01pm |
+1, like we used to do in the old vans, build a frame.
Posted: 16 Jan 2018 at 5:46pm |
Just so you know, the studs are not designed to carry much weight. You will note your current bed is carried entirely by the floor, and only secured to the wall to hold it in place. The entire interior is in place on the floor before the walls are installed. I would build my framework straight up from the existing, or build a new taller frame.
Posted: 16 Jan 2018 at 4:20pm |
Pods don't have studs persay, they have aluminum framing. Best is with a metal stud finder. Lowes and Home depot have adequate ones.
I would note where bed is attached now and try going straight up from that. First try. |
ElkCamp
Newbie Joined: 16 Jan 2018 Location: TX Online Status: Offline Posts: 1 |
Posted: 16 Jan 2018 at 3:44pm |
I am raising the bed in our new 180 model about 5". I'd like to know where the wall studs are so I can tie the new frame I'm building into at least one or two studs on each sidewall.
The factory isn't making that information available (Bad policy in my opinion as a customer). Does anyone have any ideas on helping find the studs in the wall? The pictures of fabrication of RPod on the internet don't show the 180 and I assume that wall is probably somewhat unique. When done the water heater and water pump will be much more accessible without having to take the mattress out, and it will provide a much better place for the dogs to stay. Any help is appreciated.
