Help with generator |
Post Reply | Page 123 5> |
Author | ||
Topic: Help with generator Posted: 27 Dec 2017 at 10:45am |
The reason is simple: Gasoline has a higher energy density than propane. Gasoline has 114,500 BTU/gallon. Propane has 91,500 BTU/gallon.
Therefore, gasoline can generate more power. The flip side is that
propane has a higher octane rating and burns a lot cleaner than gasoline. Propane engines can last
much longer.
mjlrpod
Posted: 27 Dec 2017 at 8:07am | |
I'm not sure if it has been mentioned in the thread at some point, but running a genny on propane will not put out the same wattage as running on gas. I don't really know why, but thats what I have been told.
Posted: 26 Dec 2017 at 7:49pm | |
I bet this starts your pod air conditioner and the microwave at the same time. Maybe even a hair drier and coffee pot too! |
VancleVector
Newbie Joined: 25 Dec 2017 Location: chicargo Online Status: Offline Posts: 5 |
Posted: 26 Dec 2017 at 1:49am | |
Second, for portable generator.
My experience is that people want (a) easy and (b) cheap.so I'll focus on portable units. Where are you going to (1) store your generator (2) set up the generator to use it? Remember, it may be severe weather so, where could you put it to keep it safe and be able to refuel it easily? If you're using power cords, will they be dry and as far out of the way as possible? Small generators (less than 5500 watts) can only do so much. If you overload the unit and damage it, you won't have any power at all. So be smart! Portable units are made up to almost 20k watts but they're not for people on budgets. The bottom line is to add up the load (watts) you plan to connect and size your generator at least 25% higher. When motors like the compressor in the refrigerator start up there is a sudden draw of power higher than the normal running load and you want to compensate for that. Small appliances will have the wattage marked on them. Lighting circuits will be less than 1200 watts each. Water heater is 4500 watts alone. Also,you'll truly get what you pay for...unless you buy from one of those guys selling from the back of their pick-up truck (don't do that). Don't wait till the last minute or you'll be stuck with whatever is left in the stores. I got a cummins genenerator and it is hard to find a place for storing. Oh, and the "trick" with connecting the generator to the dryer outlet to backfeed the house? DON'T YOU DARE!! It will result in damage and/or injury... Hope that helped a little...sorry it's so wordy |
Never too late to learn
VancleVector
Posted: 26 Dec 2017 at 1:47am | |
First, for Propane generator. I purchased a Propane Generator from Central Maine Diesel a few years ago.
20 HP Honda engine, Italian generator head. Paid about $2300 plus shipping via Paradise Freight which was a few hundred. I see the price is just a bit higher now... But the one I want most is Yuchai which i saw from a website. Recently it blew a capacitor. Central Maine sent me 2 for the price of one even though it is out of warranty. $39 total for two. I looked at generators on island but a similar Honda at Quality electric was close to $6000 and it wasn't even a 13750kw. More like 8 or 9000kw if I remember right..... They have many generators at great prices but this is the one I settled for. Quiet, no smell, propane lasts forever........ |
TheBum
Posted: 18 Dec 2017 at 6:32pm | |
I'd be leery of using a carrier like that since our Pod doesn't have risers. I'm not really inclined to add risers because of the hit to my already marginal gas mileage. |
Posted: 18 Dec 2017 at 6:16pm | |
I have a BAL Hide-a-spare tire carrier available. I am no longer using it since we got the pickup. I don't know how much shipping would be though. They sell new on Amazon for about $100. Mine was the 28210 and was modified to fit the RP179 frame distance. That should be the same for other models also. |
TheBum
Posted: 18 Dec 2017 at 5:55pm | |
I've considered carrying one of our Honda 2000 generators on a carrier in the back and the other on an A-frame tray (the aforementioned Stromberg-Carlson). They would roughly cancel each other out weight-distribution-wise and the weight on the back should be supportable (~50 lbs for the generator plus the rack weight). Unfortunately, I'd have to figure out a place to put the spare.
Posted: 18 Dec 2017 at 5:41pm | |
I also would bolster the support, possibly use the ends of the frame rails. I wouldn't be comfortable with the present set up. Shouldn't be much of a project to add support arms.
SteveA
Groupie Joined: 19 Jul 2017 Location: Sandpoint Id Online Status: Offline Posts: 56 |
Posted: 18 Dec 2017 at 11:58am | |
I like your setup but am a little concerned about the weight as well. I'm almost done with a custom designed, smaller and lighter rack for the hitch as well that will hold our Honda 2000i and 2 Gal Rotopax gas can. What I hope to achieve is the ability to store, tote and lock down the gen in the same spot it will be used as well as not to be next to where I sleep or watch tv (tongue area) in the 179. The spare tire will go under the back between the frame on a swing out system.
