  New Posts New Posts RSS Feed: Toilet Flush
Topic ClosedToilet Flush - Event Date: 06 Nov 2017 - 11 Nov 2017
geelse View Drop Down
Direct Link To This Post Calendar Event: Toilet Flush
    Posted: 12 Nov 2017 at 11:54am
Poor water flow into toilet for flush. Maybe 50% decrease in water flow from previously. Rig is 2013 R Pod 177. Last trip two months previous, no problems. This started first day and continued through week. Not using water tanks or pump, have always used connection to rv park water source. Not having any issue with water flow to sink, that is OK.
Anybody out there got idea of possible cause, and repair?
Thank you.
See America First
2013 R-POD 177 HRE
2005 Dodge Dakota Quad Cab
George and Linda
mcarter View Drop Down
Direct Link To This Post Posted: 12 Nov 2017 at 1:08pm
On city water - and you have adequate pressure at the sink, the bathroom sink? SO we are assuming you have adequate pressure to toilet. There is a water inlet valve, with a filter screen I believe. Also the rim wash holes could be clogged. You didn't mention any leaks, anywhere. I'm looking for the manual for the RPod toilet on line, it has a troubleshooting section.
Direct Link To This Post Posted: 12 Nov 2017 at 11:37pm
Water pressure was no problem, good in kitchen and bathroom sinks. No leaks found. Rim wash was not clogged. Thanks for the info about filter screen, will check. Appreciate your help.Smile
See America First
2013 R-POD 177 HRE
George and Linda
