Page 12> |
Author | ||
RFrog ![]() Newbie ![]() ![]() Joined: 10 May 2021 Location: Santee Online Status: Offline Posts: 16 |
![]() Posted: 12 Sep 2021 at 4:57pm |
While my poor little Frog is stuck in Southern AZ with the slide out, I have asked the repair place to install the steps for me. It will run about $500 including steps, install, and removal of the existing steps. Having priced the Sturdy Steps online and finding they are upward of $400, figured this would be a good addition. Even with our steps braced, I still feel like they will bend/break, so for me the Sturdy Step is a good investment. I hope you can find something that works for you.
~dani~ 2019 RP180 purchased 5/15/21; towed by 2014 Willys Jeep Wrangler Unlimited
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3365 |
Any simple lubricant should take care of that. We simply use straight silicone in a spray can. Multiple uses: steps, hinges on door as well as for waterproofing the r-dome. We spray our r-dome every other year with straight silicone, keeps us dry with no leaks. |
TEDDY ![]() Groupie ![]() ![]() Joined: 22 Oct 2017 Location: Arkansas Online Status: Offline Posts: 94 |
I use spray lube on mine - makes them quiet for about a week.
Teddy
Thin Air ![]() Newbie ![]() Joined: 06 Nov 2019 Online Status: Offline Posts: 4 |
Is the Lippert product quieter than the steps that came on our 2017 Model 180? I get up early when we are camping and the stock steps make so much creaking and rattling noise that I am afraid it will wake neighbors in adjacent camp sites.
I can fiddle with drills, saws, and angle grinders, but I'm way too ham fisted for violins...
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2718 |
I would first need to learn the fiddle. ![]() |
I also had to make a couple of shims to fill the excess space between the new steps and the existing brackets.
That is why it took me so long, I am a slow fiddler
I don't recall it taking me quite that long with the steps I bought but it did require some modifications and fiddling to get the mounting right.
After adding the riser kit to our 177 5 years ago (which only took 1 hour using basic hand tools) it was necessary to add a 2-step replacement. That took much longer to complete. Purchased the Stromberg-Carlson step, which seems sturdy enough for us, but took me about 2.5 hours by the time I removed the old step, used a hack saw to cut some notches in the new step, and then drill a couple new holes so that it would pretty much set in under the door just like the original one stepper. I am not aware of anyone who offers a 2-step unit that is basically a bolt-on add w/o making some modifications.
Page 12> |
