How to convert table to bed in 179? |
SqueakyToy17
Newbie Joined: 16 Mar 2017 Location: Washington Online Status: Offline Posts: 21 |
Topic: How to convert table to bed in 179? Posted: 01 May 2018 at 4:08pm |
I use a anti-slip rug "mat". It works like a charm. My grandson is a whirligig and it at least keeps the cushions where they belong...him and his bedding is a different story.
I got mine from Lowe's but suspect it would be at any home DIY store. :) |
Posted: 14 Apr 2018 at 10:21pm |
See my mods (link in signature). I just finished my mod to accomplish this.On ours, the seat is 4" thick so the replacement cushions I made are also 4" thick and I use a 1" support under the 3/4" plywood platform I made to make the plywood level with the slide-out base.
Andy
Groupie Joined: 11 Feb 2018 Location: Texas Online Status: Offline Posts: 65 |
Posted: 14 Apr 2018 at 7:32pm |
We found a good solution to that. throw away all the funky cushion "things" on the couch. Have a 4" foam back made & covered that is 75" long and ~ 15-16" high. Cut a 3/4" plywood that is same measurement as the back and you can lay it on the two "foot stool" things without the cushions. the seat of the couch is 3" and the back cushion is 4" so that difference makes the whole thing level. We put a twin mattress protector, a twin fitted sheet around the two cushions and it works like a charm. In the morning, remove bed linens, slide the board under the seat cushion and it's a couch again.
rpodmybe
Newbie Joined: 17 Nov 2017 Online Status: Offline Posts: 5 |
Posted: 29 Nov 2017 at 3:24pm |
Bum, any pictures of this set-up?
TheBum
Posted: 09 Oct 2017 at 11:37am |
We took the interim step of using an air mattress. It easily stowed away in the ottoman. We now have an IKEA futon (jackknife sofa), which solved the bed problem and the uncomfortable back cushion problem.
DavMar
Senior Member Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Posted: 09 Oct 2017 at 10:01am |
If I remember right somewhere on this forum someone posted a video of what I believe he did for that problem was buy an sleeping bag and piece of memory foam to insert inside it which made its own mattress. Nice idea except then you have this sleeping bag and foam to store someplace? |
Podizzi
Newbie Joined: 30 Jun 2017 Location: Phoenix, AZ Online Status: Offline Posts: 39 |
Posted: 09 Oct 2017 at 8:07am |
The table folds down and the cushions are put on top of it. Not a very good design as the cushions tend to slide off when our grandson sleeps on it. Contemplating a solution.
Podizzi
2017 rpod 179 2016 Toyota Sequoia Phoenix, AZ |
Jojogunn
Newbie Joined: 31 Aug 2017 Online Status: Offline Posts: 1 |
Posted: 08 Oct 2017 at 3:57pm |
OK -this is not easily found in the material I have reviewed. How do you convert the dinette to a bed in the 179's?
