  New Posts New Posts RSS Feed: removing battery to charge
Topic Closedremoving battery to charge
PodBarb View Drop Down
Direct Link To This Post Topic: removing battery to charge
    Posted: 05 Oct 2017 at 9:55pm
Need to remove batter to charge and not sure if using a wrench to disconnect the connections is safe.
2017 RPod 171
2017 Kia Sorento SX
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 05 Oct 2017 at 10:22pm
Yes, sure, you can use a wrench.  Disconnect the negative terminal first and be careful.  Is your pod in storage or somewhere you can't leave it plugged in?  The on-board charger-converter does a great job of keeping the battery topped off if you have shore power.
Direct Link To This Post Posted: 05 Oct 2017 at 11:15pm
Hi, thanks for the support - feel a bit foolish. Yes, it is in storage as I can't park it where I live. It's been about 3 weeks and it measures at 11.75. I'm camping nearby next week for 3 days, which might rev it up, so waffling on the charging.
2017 RPod 171
2017 Kia Sorento SX
Direct Link To This Post Posted: 06 Oct 2017 at 7:24am
If you can't plug in where stored, and intend to leave the battery in when stored, adding a battery disconnect switch is a very good idea.
Direct Link To This Post Posted: 06 Oct 2017 at 11:04am
Yes, I was looking into that. What type of battery disconnect is best. For now, I have only one battery and would prefer something on the outside of the battery case and protected from weather.
2017 RPod 171
2017 Kia Sorento SX
Direct Link To This Post Posted: 06 Oct 2017 at 11:11am
We used this one. Attached it to the top of the battery box, no issues.
Switch
Looked like this, installed...
Direct Link To This Post Posted: 06 Oct 2017 at 11:34am
We should also remind you that batteries will "self discharge", even when disconnected from everything. We keep our R-pod in storage when we're not using it, and can not guarantee that we will be back to it to top up the batteries. So after every trip, we remove the batteries and keep them in the garage where we can top them up once a month or so.
How long you can go without topping up batteries will probably vary according to battery age and local temperatures. However, I wouldn't go beyond 2-3 months between charges.
Direct Link To This Post Posted: 06 Oct 2017 at 12:04pm
I use a different style battery cut-off switch. It does not have a removable key. It is okay in moist environments.
The picture also shows the battery lock-down bar I made.
Direct Link To This Post Posted: 06 Oct 2017 at 9:25pm
Your setup is impressive. My wisdom has yet to arrive it seems. I just found out I have a bigger problem than the battery. I have lost the key to the coupler lock and no electricity available for cutting it off or drilling it out. Boy, do I feel so frustrated with all the newbie things! Got to get through them, however, because I went to go! Thanks for the picture - that really helps.
2017 RPod 171
2017 Kia Sorento SX
Direct Link To This Post Posted: 06 Oct 2017 at 9:28pm
Sending picture helps. I think it looks workable. Thanks
2017 RPod 171
2017 Kia Sorento SX
